Hello all, been a lurker for some time....
Background; I have a 2015 Golf Wagon TDI *S* (didn't want leaky roofs)
I upgraded to a 2018 glossy touch screen 8" and MIB2 brain with all new piano finish decors for whole dash few months ago:
3Q0 035 844 A Brain and 5G6 919 605 A Screen and its coded to: 02730200FF00000051220001001808009F0304F40120010002
I had the dealer remove CP and code it to my VIN using the FeCs and SWAP using ODIS. Everything but CarPlay/Android Auto (have USB/aux port installed) works as expected BUT I have a problem with poor sound quality/volume. I have working Sirius, Voice Commands, Bluetooth.
It sounds OK but is nowhere as loud as it used to be with the older 5F MIB1 unit installed. I have coded it multiple times over and over again and I can't get it to sound as good as it used to. I do not have Fender/Dynaudio as its a S trim, and I don't feel like going through the hassle of upgrading in the winter months.... MAYBE in the spring time.
When vehicle is started it says FENDER AUDIO on the display and I do not have external amplifier selected in the Login. Cranking up the volume you can hear something is "limiting" the bass and volume when you get over 1/3 volume ! I drive a lot on the highway and sometimes I like to jam pretty loud to keep me awake on my 80 mile one way commute to the daily grind!
I have checked everything, and I think the unit was/is still set up to be in a Fender car ? Came from a GTi Sport from AutoHaas. Strange that VCDS shows 47 "sound system" when connected and doing module CAN bus roll-call. Clicking on 47 doesn't bring up the amplifier.
As a side note, if I buy the "Activation" online will Android Auto work? I have reached out to Jack multiple times and got nothing back, I may just try that Retrofit page on FB.
Thanks for any help fellas!
