DIY MIB1 to MIB2 Infotainment Conversion (Part 1)
Vinay
Rotterdam nederland
Ride
Golf 7
Hello,
I have retrofitted my 2014 Golf 7 from mib 1 6.5 without nav to a 2.5 mib 9.2 inch.
Bought a plug and play unit
Everything works, carplay, navigation, bluetooth, voice command.
have coded the navi to my mfd, changed the start screen and fixed the camera(have none)
the unit came from a e-golf, so its coded with menu’s from the E.
does somebody how in can hide the e manager menu, and maybe also the e golf picture?
And also this menu electric drive and charge.
I have vcds, but dont know what adaptions to change to hide this.
and also the light from the screen dont dims when the headlights are on
Hope to hear from somebody.
George Ab
Pacific NW
To change the picture and general colors (blue for R, red for GTI, etc.), I believe it is byte 18 in the 5F module. I would go to the byte 18 and verify the E-Golf is selected and then change to Golf. I did not get my vagcom out to verify. So verify first, before changing.
Vinay
Rotterdam nederland
Ride
Golf 7
Hello,
this i already changed
i cant see the long coding helper, so coding is a litte bit harder for me.
only see the bytes like this
gianry
Italy
Hello,
send me a complete scan of adaptation and coding of your discover pro .
I could verify which parameter to change
Vinay
Rotterdam nederland
Ride
Golf 7
No, i have the same problem as you.
I see on the blue trainer only the average consumption, cant see the performance monitor. I have activated all the sport menu in adaptions but the menu doesn’t show.
Riddick20
Parma - Italy
Hello,
You said that everything works ... but does the performance monitor work 100% well?
gianry
Italy
I’ve the following situation for blu trainer menu . All the others values are correct .
In Performance monitor only g force value is correct
c_tietjen
Utah
trying to figure out what i need for a larger screen. i currently have the 6.5 inch screen and tax return has me itching for a larger screen.... i know to go with the 8 inch i will need a new trim bezel. do the 8 inch and 9.2 inch screens use the same bezel? can i use the 9.2 screen on my car without having mib2.5? or is it exclusive to 2.5? does the 9.2 screen require any new wiring or connectors or is it plug and play like the 8 inch?
KyACRASH
8" and 9.2" glass screens both use the same trim, but the 9.2" requires the MIB 2.5 brain.
8" matte screen uses a different trim.
sdmcoupe
San Diego
Ride
2015 VW GTI SE
I finally got a hold of Jack and setup a time with him. What surprised me was that he said i needed a d-link dub e-100 usb adaptor. Had to be be a dub e-100 type. I don't see that mentioned in these threads at all so I thought id mention it for anyone trying to work with Jack.
