Retrofitted dynaudio mib2
The sound is not perfect and the sub is producing sound and bass rather then just bass
Is this coding?
Any instructions on how to route the wire for the usb/aux? Did you remove panels on the passenger side or did you remove the glove box? If so, how did you do it?
Is this coding?
Hi
Thanks for your help and these options have been checked
I think the amp itself needs coding
Can anyone share the coding for a mib2 amp
47 - sound system long coding
As I have a fault saying control module not coded
;SW:5Q0-035-456 HW:5Q0-035-456 --- Sound System
;Component:MIB2_lite_amp H20 0130 Coding:2200000000AAAAAA000000000000
;EV_AMPMst12C1Gen2ALPI 1003 EV_AMPMst12C1Gen2ALPI.rod
;Tuesday 23 May 2017 12:00:12:51554
;VCDS Version: Release 17.1.3 (x64) Data version: 20170320 DS267.7
;VCID: 6DFF3AE7BC589C2932-8038
IDE10493-MAS03001-Electrical test 2 of loudspeakers-Mode automatic
IDE10493-ENG117360-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_1_Test_Frequency 19000 Hz
IDE10493-ENG117361-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_1_Test_Volume 60
IDE10493-ENG117378-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_10_Test_Frequency 19000 Hz
IDE10493-ENG117379-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_10_Test_Volume 60
IDE10493-ENG117380-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_11_Test_Frequency 19000 Hz
IDE10493-ENG117381-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_11_Test_Volume 60
IDE10493-ENG117382-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_12_Test_Frequency 19000 Hz
IDE10493-ENG117383-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_12_Test_Volume 60
IDE10493-ENG117384-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_13_Test_Frequency 19000 Hz
IDE10493-ENG117385-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_13_Test_Volume 60
IDE10493-ENG117386-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_14_Test_Frequency 19000 Hz
IDE10493-ENG117387-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_14_Test_Volume 60
IDE10493-ENG117388-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_15_Test_Frequency 19000 Hz
IDE10493-ENG117389-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_15_Test_Volume 60
IDE10493-ENG117390-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_16_Test_Frequency 19000 Hz
IDE10493-ENG117391-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_16_Test_Volume 60
IDE10493-ENG126164-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_17_Test_Frequency 19000 Hz
IDE10493-ENG126165-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_17_Test_Volume 60
IDE10493-ENG126166-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_18_Test_Frequency 19000 Hz
IDE10493-ENG126167-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_18_Test_Volume 60
IDE10493-ENG126168-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_19_Test_Frequency 19000 Hz
IDE10493-ENG126169-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_19_Test_Volume 60
IDE10493-ENG117362-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_2_Test_Frequency 19000 Hz
IDE10493-ENG117363-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_2_Test_Volume 60
IDE10493-ENG126170-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_20_Test_Frequency 19000 Hz
IDE10493-ENG126171-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_20_Test_Volume 60
IDE10493-ENG126172-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_21_Test_Frequency 19000 Hz
IDE10493-ENG126173-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_21_Test_Volume 60
IDE10493-ENG126174-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_22_Test_Frequency 19000 Hz
IDE10493-ENG126175-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_22_Test_Volume 60
IDE10493-ENG126176-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_23_Test_Frequency 19000 Hz
IDE10493-ENG126177-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_23_Test_Volume 60
IDE10493-ENG126178-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_24_Test_Frequency 19000 Hz
IDE10493-ENG126179-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_24_Test_Volume 60
IDE10493-ENG117364-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_3_Test_Frequency 19000 Hz
IDE10493-ENG117365-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_3_Test_Volume 60
IDE10493-ENG117366-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_4_Test_Frequency 19000 Hz
IDE10493-ENG117367-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_4_Test_Volume 60
IDE10493-ENG117368-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_5_Test_Frequency 19000 Hz
IDE10493-ENG117369-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_5_Test_Volume 60
IDE10493-ENG117370-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_6_Test_Frequency 19000 Hz
IDE10493-ENG117371-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_6_Test_Volume 60
IDE10493-ENG117372-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_7_Test_Frequency 19000 Hz
IDE10493-ENG117373-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_7_Test_Volume 60
IDE10493-ENG117374-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_8_Test_Frequency 19000 Hz
IDE10493-ENG117375-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_8_Test_Volume 60
IDE10493-ENG117376-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_9_Test_Frequency 19000 Hz
IDE10493-ENG117377-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_9_Test_Volume 60
MAS02809-MAS02870-Check tone frequency-High note frequency range 4000 Hz
MAS02809-MAS02871-Check tone frequency-Medium note frequency range 1000 Hz
MAS02809-MAS02872-Check tone frequency-Low note frequency range 100 Hz
Great job with your DIY.
If I wanted to have driver profile selection installed (switches and coding) 5G0054809 - could I just purchase the kit online like the one found here and code everything myself without needing ODIS?
