HOW TO IDENTIFY THAT YOU HAVE MIB2STD TECHNISAT/PREH
1.PRESS AND HOLD MENU BUTTON ON MIB2 AND GO TO SOFTWARE UPDATE/VERSION
2.AND CHECK YOUR SW TRAIN VERSION
3.IF YOUR SW IS MST2_XX_XX_ZR/PQ_ P0363T(AND ENDING WITH LETTER " T ")
4.AND FINALLY CHECK THAT YOU HAVE 2 SD CARD SLOTS
5.AND THIS THREAD IS FOR YOU
In the case of headunits from the Technisat/preh with 2 SD card slots (navigation version), the update Patch simply works via SD card.
First, the unit must be brought to a common firmware version (original firmware on the device & fully patched firmware version in the Patch CP OFF directory).
There is no need to modify any files. and note that headunits with hw ver: 010 and sw ver 01xx only mirrorlink works no AA or carplay because those units are made before 2016 dont have android and apple support because they have very little ram to process
1. Copy firmware update \ SEAT_ZR \ MST2_EU_SE_ZR_ P0363T _5F0919360E to FAT32 formatted SD card and perform the update.
2. Insert the SD card in SLOT 1 (remove all other SD cards from the slots during the update process)
3. Update the device by pressing and holding the menu button -> FW update. unit will restart few times and finally you get a option to cancel,click cancell and unit reboots
4. Format the SD card again or delete it.
5. Then copy the content of the patch from the CP OFF folder \ ZR \ SEAT \ MST2_EU_SE_ZR_ P0363T \ FEC_ALL_CID_OFF_SPORT to the SD card and perform the update again.
6. Insert the SD card in SLOT 1 (remove all other SD cards from the slots during the update process)
7. Update the device by pressing and holding the menu button -> FW update.
Note:
CP off (deactivate component protection) is not required for mib2 headunits made after 2016 which originaly came with car
(CP= component protection is for mib2 retrofiterrs who upgrade thier head unit from mib1 or simply they have cp active on screen)
Apple Carplay, AndroidAuto, MirrorLink, NAVI ,voice control is activated, whereby nothing changes in the view of the supported and activated (valid) codes in the FEC / SWAP list in the device itself.
firmware and patches can downloaded from here
mibsolution.one
password: guest
you can aslo install mibtoolbox to fix errors of Software erroes in 5f
for cp off retrofiters there will be error of cp in 5f and gateway but this dosnt do anything regarding function of mib2 unit
Note:
mibsolution.one
password: guest
#PATCH FUNCTIONS:
NoneBashCSSCC#GoHTMLObjective-CJavaJavaScriptJSONPerlPHPPowershellPythonRubyRustSQLTypeScriptYAMLCopy
├───PQ
│ ├───SEAT
│ │ ├───MST2_EU_SE_PQ_P0252T
│ │ │ SE_PQ_P0252T_FEC_ALL_CID_OFF_CP_OFF_FIXED.7z
│ │ │ SE_PQ_P0252T_FEC_ALL_CID_OFF_FIXED.7z
│ │ ├───MST2_EU_SE_PQ_P0369T
│ │ │ SE_PQ_P0369T_FEC_ALL_CID_OFF_CP_OFF_FIXED.7z
│ │ │ SE_PQ_P0369T_FEC_ALL_CID_OFF_FIXED.7z
│ │ └───MST2_EU_SE_PQ_P0478T
│ │ SE_PQ_P0478T_FEC_ALL_CID_OFF_CP_OFF_FIXED.7z
│ │ SE_PQ_P0478T_FEC_ALL_CID_OFF_FIXED.7z
│ ├───SKODA
│ │ ├───MST2_EU_SK_PQ_P0138T
│ │ │ SK_PQ_P0138T_FEC_ALL_CID_OFF_CP_OFF_FIXED.7z
│ │ │ SK_PQ_P0138T_FEC_ALL_CID_OFF_FIXED.7z
│ │ └───MST2_EU_SK_PQ_P0253T
│ │ SK_PQ_P0253T_FEC_ALL_CID_OFF_CP_OFF_FIXED.7z
│ │ SK_PQ_P0253T_FEC_ALL_CID_OFF_FIXED.7z
│ └───VW
│ ├───MST2_EU_VW_PQ_P0138T
│ │ VW_PQ_P0138T_FEC_ALL_CID_OFF_CP_OFF_FIXED.7z
│ │ VW_PQ_P0138T_FEC_ALL_CID_OFF_FIXED.7z
│ ├───MST2_EU_VW_PQ_P0254T
│ │ VW_PQ_P0254T_FEC_ALL_CID_OFF_CP_OFF_FIXED.7z
│ │ VW_PQ_P0254T_FEC_ALL_CID_OFF_FIXED.7z
│ ├───MST2_EU_VW_PQ_P0369T
│ │ VW_PQ_P0369T_FEC_ALL_CID_OFF_CP_OFF_FIXED.7z
│ │ VW_PQ_P0369T_FEC_ALL_CID_OFF_FIXED.7z
│ └───MST2_EU_VW_PQ_P0478T
│ VW_PQ_P0478T_FEC_ALL_CID_OFF_FIXED.7z
│ VW_PQ_P0478_FEC_ALL_CID_OFF_CP_OFF_FIXED.7z
│ VW_PQ_P0478_FEC_ALL_CID_OFF_CP_OFF_SKIN_FIXED.7z
└───ZR
├───SEAT
│ ├───MST2_EU_SE_ZR_P0253T
│ │ SE_ZR_P0253T_FEC_ALL_CID_OFF_CP_OFF_SPORT_FIXED.7z
│ │ SE_ZR_P0253T_FEC_ALL_CID_OFF_SPORT_FIXED.7z
│ ├───MST2_EU_SE_ZR_P0369T
│ │ SE_ZR_P0369T_FEC_ALL_CID_OFF_CP_OFF_SPORT_FIXED.7z
│ │ SE_ZR_P0369T_FEC_ALL_CID_OFF_SPORT_FIXED.7z
│ └───MST2_EU_SE_ZR_P0479T
│ SE_ZR_P0479T_FEC_ALL_CID_OFF_CP_OFF_SPORT_FIXED.7z
│ SE_ZR_P0479T_FEC_ALL_CID_OFF_SPORT_FIXED.7z
├───SKODA
│ ├───MST2_EU_SK_ZR_P0253T
│ │ SK_ZR_P0253T_FEC-ALL-CID-OFF-SPORT-FIXED.7z
│ │ SK_ZR_P0253T_FEC_ALL_CID_OFF_CP_OFF_SPORT_FIXED.7z
│ ├───MST2_EU_SK_ZR_P0367T
│ │ SK_ZR_P0367T_FEC_ALL_CID_OFF_CP_OFF_SPORT_FIXED.7z
│ │ SK_ZR_P0367T_FEC_ALL_CID_OFF_SPORT_FIXED.7z
│ ├───MST2_EU_SK_ZR_P0369T
│ │ SK_ZR_P0369T_FEC_ALL_CID_OFF_CP_OFF_SPORT_FIXED.7z
│ │ SK_ZR_P0369T_FEC_ALL_CID_OFF_SPORT_FIXED.7z
│ └───MST2_EU_SK_ZR_P0480T
│ SK_ZR_P0480T_FEC_ALL_CID_OFF_CP_OFF_SPORT_FIXED.7z
│ SK_ZR_P0480T_FEC_ALL_CID_OFF_SPORT_FIXED.7z
└───VW
├───MST2_EU_VW_ZR_P0140T
│ VW_ZR_P0140T_FEC_ALL_CID_OFF_CP_OFF_SPORT_FIXED.7z
│ VW_ZR_P0140T_FEC_ALL_CID_OFF_SPORT_FIXED.7z
├───MST2_EU_VW_ZR_P0254T
│ VW_ZR_P0254T_FEC_ALL_CID_OFF_CP_OFF_SPORT_FIXED.7z
│ VW_ZR_P0254T_FEC_ALL_CID_OFF_SPORT_FIXED.7z
├───MST2_EU_VW_ZR_P0369T
│ VW_ZR_P0369T_FEC_ALL_CID_OFF_CP_OFF_SPORT_FIXED.7z
│ VW_ZR_P0369T_FEC_ALL_CID_OFF_SPORT_FIXED.7z
└───MST2_EU_VW_ZR_P0478T
VW_ZR_P0478T_FEC_ALL_CID_OFF_CP_OFF_SPORT_FIXED.7z
VW_ZR_P0478T_FEC_ALL_CID_OFF_SPORT_FIXED.7z
└───Unit Type [ZR/PQ]
└───Brand [VW/SKODA/SEAT]
└───Train [e.g. MST2_EU_VW_ZR_P0478T]
└─── Patch Archives
https://mibwiki.one/collection/technisat-mst2-jBPg27wCzU
Share your knowledge with fellow VAG-Heads to collectively build on the newest hacks or solutions.
At the moment we are mostly focused on MIB solutions but this should be considered an open board to share knowledge about our favourite VAG cars.
To discuss anything on this board get in touch on either:
- FEC_ALL - Exception list with support for MY2020+ cars
- CID_OFF - 3rd party SD cards enabled
- CP_OFF - Component Protection patched
- SPORT - Skin changed to add SPORT screen
#Fixed
Old patches until now - 14.01.2022 - have multiple issues, which are fixed in this new collection of patches:- Exception List support on cars 2020+ (issue mainly on VW)
- fixed connect issues after patching
#Patch list
List last updated: 14.01.2022NoneBashCSSCC#GoHTMLObjective-CJavaJavaScriptJSONPerlPHPPowershellPythonRubyRustSQLTypeScriptYAMLCopy
├───PQ
│ ├───SEAT
│ ├───SKODA
│ └───VW
└───ZR
├───SEAT
├───SKODA
└───VW
#Patch archive - naming convention
Folder structureNoneBashCSSCC#GoHTMLObjective-CJavaJavaScriptJSONPerlPHPPowershellPythonRubyRustSQLTypeScriptYAMLCopy
└─── Patch Archives
#Naming of patch archives:
[Brand][Unit Type][TRAIN][PATCH FUNCTIONS][FIXED]NoneBashCSSCC#GoHTMLObjective-CJavaJavaScriptJSONPerlPHPPowershellPythonRubyRustSQLTypeScriptYAMLCopy
- Telegram: https://t.me/joinchat/T_pADdwJyUXq0VoH
- Discord: https://discord.gg/YU3rjatWjT
MST2 - DIY - How To create an SD patch
InfoWarningTip
MIND that every intervention on your system can end in a boot loop. If this happens you have to flash the original FW via emergency download (more details)! Everything happens on your own risk!
#Basic information (read first)
InfoWarningTip
With this tutorial you will be able to create your own SD Card patch depending on your system and needs.
InfoWarningTip
Read all steps before start working with this!
#Tools required
- “MST2_DIY_SD_patch_bundle.7z” tool package stored on MIBSolution in MQB_Solution/MST2 - TechniSat Preh/Instruction
- FW on your unit or better and easier the FW file you want to update to
#Steps
InfoWarningTip
If you want to build a new Patch, always use a fresh download of DIY SD Patch.7z.
InfoWarningTip
Never use the template again if you already build a patch with it!
Always start from a clean copy.
The “xx” in some file names and folders below are place holders, as these parts differ depending on the FW you are working with.
Every JXETool will create a modified file in the same place as the original file is stored.
There is also a German Liesmich.txt coming with the archive ;-)
#CP OFF, or FEC ALL or CID OFF
InfoWarningTip
Decide which patches you need: CP_OFF, or FEC_ALL or CID_OFF
#FEC_ALL (modify “tsd.mibstd2.system.swap”)
InfoWarningTip
This will enable all FECs supported by unit
- Get cpu_swap_xx_default.tar.gz in foldercpu/swap/xx/default/ from FW file
- Get tsd.mibstd2.system.swap stored in tsd/bin/swap/
- Unpack this file into /JXETools/ folder and runSWaPPatcher.exe
- It will run for a bit and output tsd.mibstd2.system.swap.patch, copy this file into _patch_template/cpu/onlineservices/1/default/tsd/bin/swap and rename it to tsd.mibstd2.system.swap
- FECs will be added by Exception list signed_exception_list.txt which is already stored in _patch_template\cpu\onlineservices\1\default\tsd\etc\slist. Just leave the file as it is!
InfoWarningTip
No additional upload of SWAPs required with this method!
If you also need CP_OFF, continue with the CP_OFF part.
If you need only needed FEC_ALL patch you have to use HashesGenerator.exe now!
#CP_OFF (modify “tsd.mibstd2.hmi.ifs”)
InfoWarningTip
CP will be patched out - error in 5F will stay
- Get cpu_hmixx_xx_default.tar.gz in foldercpu/hmixxx/xx/default/ from FW file
- Get the whole hmi folder stored in tsd/tmp/
- Unpack the hmi folder to _patch_template\cpu\onlineservices\1\default\tsd\tmp\hmi. Get file tsd.mibstd2.hmi.ifs from _patch_template\cpu\onlineservices\1\default\tsd\tmp\hmiand move it into IFSTool folder. Run IFSTool.exe and load tsd.mibstd2.hmi.ifs
- Click “Unpack” and tsd.mibstd2.hmi-unpacked.ifs will be created in folder. Copy this file to the same folder as CPPatcher.exe (JXEToolsfolder) and run it. The file tsd.mibstd2-hmi-unpacked.ifs.patched will be generated.
- Load tsd.mibstd2-hmi-unpacked.ifs.patched into IFSTool and click “Pack”.
- Now there will be a file tsd.mibstd2-hmi-unpacked.ifs-repacked.patched. Copy it into _patch_template\cpu\onlineservices\1\default\tsd\tmp\hmi folder and rename to tsd.mibstd2.hmi.ifs
- copy the whole (modified) “hmi” folder to cpu/onlineservices/1/default/tsd/tmp/
If you also need CID_OFF, continue with the CID_OFF part.
If you need only needed CP_OFF patch you have to use HashesGenerator.exe now!
#CID_OFF
InfoWarningTip
This will add support for all SD cards for maps
InfoWarningTip
select folder below based on your FW train version 2XX, 3XX, 4XX
Copy /nav/ folder from /ID xXX/nav/ to _patch_template/cpu/onlineservices/1/default/tsd/etc/.
mibstd2_nav_target.ini is already changed to support all SD cards.
InfoWarningTip
Run HashesGenerator.exe now!
#Signing (HashesGenerator.exe)
InfoWarningTip
Do this only once at the end, when all patches you need are prepared.
After you have build your custom patches files have to be “signed” with the “HashesGenerator.exe” which is stored in _patch_template/cpu/onlineservices/1/default. It will generate the correct hashes.txt so that all files are accepted by FW update process.
#Run SD patch
If you followed the steps above you now hold a ready to go SD patch in your hand.Insert SD card into unit and install as FW update.
- Press and hold MENU button for 3 seconds to enter Service menu video.
- Go to Software update/versions → Update → continue with installation
#Alternative patch upload
You can also use these modified files with MIB STD2 Toolbox.Copy e.g. tsd.mibstd2.system.swapfile to /custom/swap on toolbox SD card … and so on for the other files …
Use functions in GEM to upload to unit.
TechniSat SWaP Patch with Toolbox
InfoWarningTip
Details about Technisat MIB STD2 Toolbox installation.
InfoWarningTip
MIB STD2 Toolbox SWaP Patching supports most common firmwares. If your firmware is not supported, report it in the repository or update firmware to the most recent/supported version.
InfoWarningTip
Performance Monitor will not be enabled by this method. You will need to upload self-generated FEC/SWaP code. More details:
MST2 FEC/SWaP Code Generator
5F - Inserting FECs with OBDeleven
source(https://mibwiki.one/doc/technisat-swap-patch-with-toolbox-MOZvFaLfYP)
- Make sure you have installed the latest version of the toolbox from here: https://github.com/olli991/mib-std2-pq-zr-toolbox.
InfoWarningTip
- Make sure that Toolbox SD card is inserted into SD1 port. It’s required for origian files backup before patching.
- Press and hold MENU button for 10 seconds to enter Testmode menue.
- Go to Green Engineering Menu → mibstd2_toolbox → Tools → Patch tsd.mibstd2.system.swap and generate EL.
- Wait about 15 seconds for the script to perform modifications.
- Press and hold volume control knob for 10 seconds to reboot the unit.
- Check if FEC/SWaP protected features are working.
InfoWarningTip
InfoWarningTip
