US spec car gets totaled (accident or flood), sold on action, brought to Poland, US-Spec lights needs to be replaced with EU-Spec, so old US-Spec lights land on Allegro for 50% value, bought by someone on US. Cycle of life for Mk7
Dont know if you've seen the emblems on the new arteons and passats. The have the areview cameras mounted in them. Might be worth a look. There is a post on drive2.com about changing the emblems to the newer style on mk7 golfs. Thanks @Reaper1 for the information.Removed the grill (2 screws, 4 locks, couple guiding pins), removed silver badge.
Applied template (16mm width, 19.85mm height). Dadge is tilted about ~ 25° from vertical, so if I drill 16mm x 16mm hole, camera would point up.
Test-fitted, checked on monitor, glued in place to make sure it's not crooked.
View attachment 267547View attachment 267548View attachment 267549
And this is how it looks. Hole could be cleaner, but not much that I can do about it now.
View attachment 267550View attachment 267551
Relay is not directly driven by arduino., its by the transistor (negative switching).How are you driving the relay coil? Directly from the arduino, or using the arduino to switch a transitor that drives the coil?
