dequardo
- America’s Dairyland
- ‘21 GLI Autobahn GLI
Shift it to M.
Is that a thing? VAGCOM is on my very short list of "mods". Planned to get it anyways to silence the damn soundaktor (I can unplug it but figured I could use the software for other little changes here and there).Should be easy for those with VAGCOM or OBDeleven to code the MFD to show the gear in D
Yup and I'd like to see around 2500 rpm at 80. I can't make a big stink about something that's pretty great but it is costing me close to 2 mpg on the highway.It's higher than that. The 6spd DSG has shorter gearing than the manual in 6th gear.
Nope. Check again next time your out and about. You're off by over 10%. I wish it was around that. It would help mileage quite a bit.
Someone who owns an 18gti said their 6spd dsg doesnt autoupshift in 1st or 2nd gear so you can bang on the rev limiter, true or false? This is a big plus over the 7spd if true.
7spd definitely does some clutch riding when taking off from a stop as I could have sworn I noticed the rpms holding steady for a much too long period as the car started accelerating. I do not like how much comfort oriented it is with gear engagement when driving moderately. When you are going full gusto the transmission seems to shift fast enough.
I would have preferred the 6spd personality with the 7 speed ratios.
The options are not well integrated. For example, if you change in to sport mode while driving, the DSG will go in to S, same with eco, but E. However, if you start the car in sport or custom with...so while typing out this post I remembered that you slide the shifter into "D" there is "D/S" down there. Does the sport option on the drive mode differ from putting the shifter into "S"? I feel like Ive had an epiphany, lol.
I think it's probably a good thing that doesn't start off in S, since (unless you were just driving the car), the fluid isn't up to temp (engine or transmission fluid).
