Disable 'engine is running' beep
lordnikon228
FU
GTI
As the title says, is there a way to disable the 'engine is running' chime when you open the driver's door? This is different than the 'ignition is ON' beep which can be disabled in OBD11.
It's quite annoying. I know the engine is running...argh
Thanks
tigeo
Turn off key-in/open door warning
Adaptation
Control unit: 17 Dash Board
Name: Ignition active message, actuator
Values:
Old value: Driver door
New value: No display
lordnikon228
FU
GTI
Adaptation
Values:
This does not work. I have already set it to 'no display' which as mentioned above, removes the ignition ON beep but not "Attention: Engine is running" beep
avenali312
Smyrna, GA
2015 VW GTI
Correct. Sometimes I'll open my door when backing into my parking space at work to make sure it's tucked in as far as I can to prevent door dings. I've had the car for years and it seems impossible to turn this off. Also have mine set to "No Display." It also does nothing about the "Remove Key" warning.
tykru
cookie21
2019 GTI
have you found a solution for this? i have the same issue and it's driving me nuts.
tykru
cookie21
2019 GTI
tykru
cookie21
2019 GTI
oh man, i've had this car for 2 weeks and it's driving me crazy. about to take it to the dealer to see if they can make it go away. you know how often i leave the car idling while i get in and out of the car, and that beep is ridiculous.
avenali312
Smyrna, GA
2015 VW GTI
Nope. I've given up haha.
