Diggs24 Build Thread - "Tapioca XL"
Diggs24
de plains! de plains!
2015 GTI
Dragy got a battery upgrade. Nintendo switch controller battery. Slightly too big but another piece of double sided tape fixed that. Went from 400 to 525 mah so it should last longer.
Diggs24
2015 GTI
Was lively this morning, spun 4th in my AS3+:sneaky:. Spools around 300rpm quicker than when it's moderately warm out. Serves as a reminder that when company X claims "Look how fast our turbo spools!" without giving any data behind important variables such as ambient temp and ambient pressure. Comparing their turbo vs yours in the deadass heat of summer is foolish. These things have a major impact.
https://datazap.me/u/diggs24/cold-weather-4th-spool-and-spin?log=0&data=8-17-56-57-68&mark=274
Versus when it was warmer out.:
https://datazap.me/u/diggs24/log-1662987976?log=0&data=8-17-56-57-68&mark=365
Used Vdyno to find where they broke loose. Looks like around 4300.
JerseyDrew77
Virginia & NC
2016 TR GTI S 6MT
https://datazap.me/u/diggs24/log-1669643945?log=0&data=8-17-56-57-68&mark=272
Hmm, I wonder who/which company you could be talking about... ;)
Diggs24
2015 GTI
@Switchleg has been hard at work bringing new capabilities to SwitchPatch, the latest being ignition-based traction control. There is an added layer of wastegate control to help prevent overboost when you cut massive amounts of timing. Big shoutout to switch on this new added feature. NOTE: You still have to start with a reasonable amount of power for it to be effective. It can't save your 550+whp GTI on winters if you give it all the business in 2nd gear.
Video of it in action (started with map2 off, map 3 on):
https://flic.kr/p/2ogBaVC
ECUs internal accelerometer don't lie: https://datazap.me/u/diggs24/log-1676239025?log=0&data=2-17
or you can look at the rear wheels to see how fast the car was accelerating. Compare the slope between the 2. Clearly faster with TC enabled: https://datazap.me/u/diggs24/log-1676239025?log=0&data=17-75
You can see it pulling timing out: https://datazap.me/u/diggs24/log-1676239025?log=0&data=17-33-34&mark=1697-1745-736-774
Here is the WG being opened to help keep boost in check. Only a few psi over, not bad: https://datazap.me/u/diggs24/log-1676239025?log=0&data=17-54-55-71&mark=1647-1751
In addition, there is an added map. Map6 is Antitheft or antiteenagerstakingmycarwithoutasking! Car no start!
https://flic.kr/p/2ogNgEV
EpicTech
Houston
MK7 GTI 6sp w/PP
Dope, imagine I will need this sometime later this year.
Subliminal
Vegas
Slow FWD VW Hatch
you're just now getting spark based tc in 2023? bruh
