Diggs24 Build Thread - "Tapioca XL"
Diggs24
de plains! de plains!
2015 GTI
RAL with boost by gear based on map selected:
Map 1 Spicy
Map 2 Spicier
Spicy in action:
https://datazap.me/u/diggs24/log-1653355881?log=0&data=8-17-105
Acadia18
The Grave, Due To Catastrophic Brake Failure
Straight Outta China
I don't know what any of this means but I'm excited because you're all excited!
904mk7
Jax
17 PP GTI
Im guessing with traction settings you can run that much that low without spinning? That's sick!
manu97
Chicago
MK7 R
No mandarin. The table is in hpa. Convert to psi and subtract ambient for your location (I'm at 14.4psi). 3000hpa=43.5psi=29psi after ambient. Gear is on the left. Top is rpm.
Ok this may be my ignorance speaking, but why are there 7 gears if you have a 2015? Or is gear 7 just not a real gear?
Switchleg
Edmonton, AB
Mk7
You can setup tuner pro to show it in psi by changing the equation but the ECU goes by absolute pressure (ambient + boost) so actual boost will always vary slightly with pressure changes. This is where the maximum pressure ratio table comes in handy to prevent the turbo from trying to make full boost at altitude.
