Diggs24
- de plains! de plains!
- 2015 GTI
Found the end of the line for not having a 5Bar MAP sensor. ECU does not like being over 30psi for more than a few seconds. Once it does it enters some sort of power reduction mode by...cutting timing? Wish I had logged the 8.05 run so I would have seen what it was doing (bad Diggs!) but now I have seen this is repeatable as I have logged it doing this twice now. Here is a 3rd into 4th and a 4th standalone. After it shifts into 4th timing starts where it should then it basically flatlines at 7-8 degrees:
https://datazap.me/u/diggs24/log-1636246570?log=0&data=1-18-28-29&mark=32-45
Just flooring it in 4th you can see timing is fine but had I kept going it would have started cutting it.
So...EQT 5bar ordered.
"Diggs, does this mean you car is going to be even faster?"
Yeah, probably. Sorrynotsorry.
