So I installed the 26mm H&R rear sway bar and did not like it , the front end pushed really bad in the corners , I removed the bar and to me I like the feeling way better with the stock bar , any of you guys run into this
Not cutting the wheel , when I would come into a corner the car would push and feel really unsettled, with the stock bar the car feels more settled, I will be honest I’m running the cheap performance tires you get for 600 for all 4
I also noticed front end push with 034's rear bar on the sofr setting. The car is much flatter when turning, so instead of removing it, I'll just add a 034 front sway eventually.
I installed the Neuspeed 25mm rear bar and noticed less understeer, but the significant reduction in rear body roll did make the front body stand out. I'll be installing the Neuspeed sport progressive springs next weekend, which will hopefully reduce body roll in front, without increasing understeer. You may want to look into dual rate progressive springs along with the rear bar for the feel and balance you want. The VWR springs are pretty linear, and therefore don't help with body roll.
