Ran the TSCC Points Event #2 autocross yesterday so here's a summary of that:
Changes since last time:
-Superpro camber bushings on the forward LCA (replaced the Powerflex bushings I'd previously installed), maxed out of course. Zero front toe.
-255/40 + 245/40R17 reverse staggered V730s (previously 245 all around)
-Koni Special Active shocks
For starters I drove like CRAP. 4hrs of sleep, I had my son with me, missed an opportunity to eat lunch before my runs since I was running around helping novices and I just never felt it. Was a really fun course, just wish I was a bit better mentally/physically prepared. I still managed fastest STH run, but I had no chance of beating Tim Aro (who is a top level national competitor for the record). I think with better driving I could have knocked off a low 40 or high 39 sec run, but I don't see any chance of doing a 38.5xx to beat Tim.
Now with all the typical racer excuses out of the way:
Observations on the car:
- The shocks are awesome. The rear was far more planted and definitely improved in overall grip moreso than the front IMO. Will require playing with higher tire pressures out back I was on my way to doing that, but my last run really needed to be a clean one so I erred on the side of caution since my driving was craptastic anyway. Also need to consider playing with adding stiffer rear springs as @xXDavidCXx recommended.
- The 255s up front I'm not sure if they really bite notably harder. Considering I also added camber, and better shocks, I was kind of hoping for more. I ran them at 29psi all around. 31 up front was tried and didn't seem to have as much bite.
- Since adding the shocks, the front bar feels more "free" if that makes any sense. I noticed this driving on the street but wanted to see if it held true when driving harder. I think that they make a big difference in helping to damp the added bar rate as well. It feels less "springy" as you pass the 0 lateral G mark transitioning from left to right or visa versa. Hard to explain, not sure that there's any data that would be able to pinpoint it either. Best I can think is that it doesn't feel like it wants to "stick" on center, the body motion is more smooth in transition I guess?
- I don't think using LC is any faster... The main benefit is that it rapidly lowers your IATs sitting on the start line. @mrmatto You can see this in the video above. It drops from 154F down to 138F in about 5 sec sitting on the launch control.
Here's the squiggly lines from my least-slow run:
Honestly the overall numbers seem ok. It doesn't "feel" like it really corners that well. I think it's because my idea of handling comes from auto-xing a 2200lb car for so long
The GTI feels much more numb by comparison. But the throttle pedal actually does things so that more than makes up for it
That said - it's not a truly valid comparison with the camber change, running at a different site, AND new shocks - BUT the overall peak to peak lateral Gs are almost exactly identical from PE1 vs PE2 data. The both have peaks up to 1.250-1.295 lateral Gs, and if you highlight the peaks where the input is held, they average out to 1.05ish Gs. I somewhat wonder if the 245s are actually faster...
Results:
Finished 3rd overall in the ST bump class (all ST* cars run against each other on PAX):
15th/113 overall in PAX:
And was 26th in raw time for the record (of 113 total timed entries).
My son Levi came along and is finally big enough to ride along so had fun hopping in a few cars. His favorite was a buddy's Skyline. And not related to the auto-x, but the day prior we took the dogs to a local outdoor brewery. They had so much fun that the little bastards tried to jump in as I was packing for the auto-x event later that night
Edit: on a side note I was also having a "12v battery low" warning - even though battery was replaced last year (and coded correctly). Made a separate post about that saga here since I finally figured it out. Battery tested good, but has diminished capacity. I think it happened due to a bullshit charging mode on my CTEK charger. Basically don't use the recondition mode on an AGM battery. Ever.
https://www.golfmk7.com/forums/inde...ad-if-you-have-a-ctek-battery-charger.422526/
