Cliff p.
- El Paso, TX
- '17 Golf R DSG
Dang! Energizer Bunny much?
9 days to superlap; this car needs to be on a trailer in 8 days. Need to get things finalized. [emoji1598]
I didn’t even have to pull the turbo I had the housing swapped in a little over an hour
I've been back there enough and know the car and my parts; didn't even have to disconnect the downpipe from the lower bracket. everything has just enough give that I could swap housings without even touching the turbine wheelI was trying to work it in my head if that was possible
Would love to see the logs post housing.
Back to spooling well? That's crazy that it spooled 1k rpm slower.
Well, it's sorted. I think my wastegate rod is ever slightly bent that it may cause binding depending on how it's set. I put the voltage up to 3.3v, found a sweet spot where the rod wouldn't give any resistance to rotate, then l locked it down and manually pulled on the rod 20 times to make sure it wouldn't bind or stick anywhere.
I'll be keeping a close eye on it near term, and will plan on replacing it if I see any oddities.
https://datazap.me/u/cliff-p/eqt-101-e50-20190621-1435hrs-4th?log=0&data=13-36-43-44
Which housing is this?
I'm on the standard housing now. I could probably go back to the XL housing, but Ed is more concerned with WGDC still being high given the boost levels. I'm going to datalog in the early morning and see if the WGDC drops at all.
When I last had the EQT installed, We had 30psi with 75% WGDC. I'm sure climate is a factor, but it shouldn't differ THAT much.
How do you read this log, and what is it logged through? Saw it and was more than curious haha.
Just to make sure I understand. base= tune. actual= where it is to hit boost target? Looks like base went up vs that hot run yesterday.
i wonder if a few more runs base wont go down as it sees wg doesn’t need to be that closed. same tune?
