bentin
- Austin, TX
- 23 Golf R - 3 Pedals
Is it possible that you did this and just forgot about it?
Great info. Really appreciate the help. Planning on taking it to a tire shop and doing exactly that. Thanks!To check wheels they need to be removed from the car.
Many things impact rotation when on the car.
They can even remove tire so they are only checking the wheel and they should measure for run out not just eye ball it.
If the tire did not seat correctly (poor soap application) the tire can wobble on the wheel and look out of round.
To bend all 4 takes a very big impact - curb or pot hole that hits all 4 wheels.
Single OE tire can be bend if pot hole big enough and two on one side can be bent but all 4 takes something special.
Find a tire shop or place like NTW of Firestone and ask them to check a couple.
If those are bad pull the other two and check.
Repair cost depends on location of damage. On face of wheel costs more. On inside of wheel less.
If bad damage they a repair could crack the wheel.
Forged wheel harder to fix than cast as the stronger wheel is harder to work.
Avg repair cost including repaint is $100.
Austins with machined face harder to repair as they also need clear coat. Mine was damaged on inside lip, so lucky.
Still $100.
Oh I completely forgot about that. Thats actually me in the video. Thanks for the reminder.Is it possible that you did this and just forgot about it?
I wonder if this is the same Polo driver that flipped one.Is it possible that you did this and just forgot about it?
