Follow up on a few findings after finishing the DCC retrofit.
I originally reported that I could hear the DCC valves actuate when turning on the GTI which freaked me out
. About the only time I hear this now is if I go to the DCC module with any of my programing tools (OBDeleven, VCP, ODIS-S). Checked my wire harness before install with my multimeter and double checked everything against the VW wiring diagram. I'm not really sure if its a problem but will check the wiring again soon.
The passenger side level sensor has an inverted value, as in it goes from 70s to 30s. Not sure what the unit of measure is. The other two level sensors go from the 30s to 70s. At first i thought that my sensor was bad, but a friend was able to validate my numbers against his Golf R with factory DCC.
Drive modes
, so comfort mode is not available unless you pay for someone to reprogram the gateway. Comes back to Swap codes and all that. I asked on the VCP forums if there is away to do it with the parameter files available on VCP and was told no, but a good alternative is loading up Passat settings on the Gateway along with index C on the DCC module to get the slider. Not super sure how to do this but will investigate and if I find out anything will definitely share.
As for ride quality, its feeling better recently. I did get an alignment which help as I'm not fighting the steering wheel anymore. Or maybe the dampers are breaking in or something.
DCC does a good job at controlling the rebound of the springs but its not the same plush feel you would get as driving something on 16" wheels. I can understand why some people think DCC is a gimmick. I'm convince they do not understanding what is happening from a physics perspective. Or maybe they set their expectations too high. Having DCC doesn't mean you have a transformer button on your V-Dub, it just makes the suspension adjust dynamicly within a control range. I do have the 034 motorsports rear sway bar for like 8 months or so. It help getting the natural GTI body roll under control. Add DCC to the mix and taking corners feels way better. I also feel like power delivery is improved especially in sport mode.
Hope this helps with anyone considering this retrofit. As with any other advance retrofit (Check out my LED Headlight retrofit
) its worth it if your getting something out of it. By the way I love my dynamic LED Headlights
