DCC Retrofit
Cuzoe
I'm sort of on vacation, away from home. My wife is working here in Montreal but she has a broken leg so I'm assisting.
I'm talking about in module 14. The module "dumps" the dataset if the VIN stored in the module doesn't match the car. I don't know if it's a full VIN comparison or just enough of the VIN to know if the car is the same type.
You don't need comfort mode for DCC. The DCC module doesn't really care what modes you have to be honest. It's just going to operate in whatever mode the Gateway data set is commanding/requesting. Comfort mode requires a FEC. So if you enable it in the Gateway data set but don't have the FEC it won't show. Almost every gateway data set I've seen has an Offroad profile setup, but most cars don't have the Off-road mode FEC so it doesn't show.
Somewhere in the gateway data set there's a default so if no other mode is requested that's the mode you'll get. And for that you can set it to be in the last mode it was in or to always default to the same.
Anyway even if you can only find a data set for a FWD Golf I would load that and at least have everything working. You can always load a different data set later. You won't even have to redo the basic settings.
jamstonmartames
North East
GOLF 7.5
I can find datasets for modules 1-13 and 19-76 but nothing for 14 :(
I'm pretty sure that this B200500 Data Record Invalid will be solved with the file.
My search for firmware: FL_5Q0907376C_0130.frf and golf r parameters: 14_OE_5Q0907376B.xml continues :cry:
Worst case, there is this option: https://www.dscsport.com/product/v4-controller-golf/ but wow that price is insane.
@Vorne Au hinten Weh @Chillout Installed it here:
Intro
Suspension performance can be measured with seat-adjuster vibration analysis, dynamic readings, track performance and on.
I do regular and spirited public road driving and have none of the measurement tools, other than my own subjective observations and comments passengers might make. Meaning this is about my personal impressions and how I got the suspension to work in ways that I like. My driving happens mostly in Ontario and the NE states.
My GTI's
My first GTI was a 2015 non-performance pack model without DCC (Digital Chassis Control = adjustable dampers). In 2019 I traded it for a 2019 Canadian Rabbit edition GTI (B-W differential lock, with DCC, no sunroof, no NAV system). On my cars I keep the complete suspension, wheels and tire size stock. Air pressure set cold at 37 psi.
What I did not like about the OEM suspension
I found the suspension of my (non-DCC) 2015 GTI o.k. but not great. Impacts were sometimes transferred harshly to the chassis. The suspension tended to crash on okay-looking road surfaces, occasionally, leaving me and passengers wonder if a wheel just got damaged. (for reference, our Honda Civic would travel across the same roads with just some thumping noises reaching the cabin, and no jolts or crashing noises).
Hoping the DCC feature on my 2019 GTO would improve things greatly I found it was not so. Only slight improvements. When overwhelmed still too harsh, still crashy here and there and still jolting people when transversing cracks with dips or pushed-up pavement bumps. Driving onto a road when there was, say, a 2” drop from the curb to the pavement always made the front end sound and feel overstressed.
Analysis
The DCC is described in the VW literature as a high-speed electronic damper tuning system, incorporating the input of three chassis accelerometers, steering angle, three chassis level sensors, brake pressure and car speed. While the three DCC settings (Comfort, Normal, Sport) certainly made a difference, my overall impression was that the system was not using all the inputs in a manner that really made the DCC suspension work much better than the non-DCC one. The programming did not seem to make much use of all the data the car generates on all the input channels. The DCC suspension still got overwhelmed in situations where other cars just thumped a bit.
I was not ready to replace springs, dampers and possibly sway bars with all the associated costs for parts, installation, any necessary alignments and camera/radar calibration. Then COVID came which really slowed down the amount of driving I could and needed to do.
Solution
In early March of this year I read in the Golf R section of this forum about a product that had just been released for use in Mark 7 and 7.5 Golf R and GTI. A plug-and-play replacement controller for the VW J250 Electronic Damping Control Unit. An intriguing idea. Simple install without shop involvement, simple uninstall.
Provided that this unit would have the advertised processing and output capabilities it appeared to be a sound engineering approach to suspension improvement.
Through discussions with the company (dscsport.com) it seemed to me they knew what they were talking about. Their website provides free software and the data tables loaded into the controller available. With these one can tweak the suspension to one’s liking by editing the data table and loading it into the controller.
They provide documentation and training videos online as well as phone and online support.
Each DCC damper in the GTI has a current-controlled oil-flow adjustment valve that is attached to the damper body. Which is more limiting in the range of oil flow control than, say, dampers with adjustment valves in the main piston which can adjust across a wider range of fluid flow. Or shocks with magnetic fluid which also have a wider range.
The Golfs also only have one rear axle chassis height sensor on the driver side, requiring a system to work without knowing where the rear right wheel is height-wise. Height data is used to calculate e.g. compression speed to add additional damping in high-speed movement situations. Yet DSC said they can make a considerable performance improvement and I decided to find out.
I installed a DSC controller unit in my car in the middle of this March. Zeroed the damper travel using their s/w. And went driving, just as the ground thawed and country roads around here were in their peak season for shifting and heaving. The car now stayed flat when cornering and no longer dived when breaking. Driving over dips and pushed-up cracks was much more pleasant and without trashy/crashing noises. For my personal feeling this was working much better than what VW had managed to do with their controller.
Adjustments
I found the base calibration setting DSC used for all four dampers a bit too hard for my liking. The VW dampers have an operating range of 240 mA (softest) to 2,000 mA (hardest). I dialled the softest setting for my dampers midway between the one DSC had chosen and the lowest possible setting. I reduced some of the compression settings as well. All good. It took a number of hours to study the controller input tables and the use of the s/w.
When installing the DCS controller with a USB cable plugged in it is easy to use a laptop for changing settings, doing live data recordings etc. The DCS controller installs in the same bracket as the VW J250 box. Inside the driver’s side rear quarter panel, right below the access flap in the carpet where one can undo a rear light plastic installation nut. Open the flap, pull out the USB cable and connect.
And now?
I am just using Comfort mode. I see no need to adjust modes no matter what driving I do. This system does a lot more adjusting, and over a wider damper range, than the VW box.
Seems the DSC Sport unit came with the same data table loaded for all three selectable modes. As I have no need for other settings I have left the other two modes alone.
As a side benefit, since the car no longer dives in the front while breaking, the rear discs get more of a workout and clean off the corrosion caused by all the salt and de-icing liquids used around here nicely now.
Related Findings
A VCDS scan found that VCDS cannot communicate with the DSC controller over the CAN bus. VCDS also reported the Steering Wheel Control Module showing a Level 2 communication error with the DSC box. There are no error lights or messages on the dashboard displays and no indications any systems are not working.
And here we are. I have used the controller for over two months now and am very pleased with the DCC suspension now. I’ll repeat, suspension performance is a very personal and subjective field and I am not saying this unit will make the GTI suspension work as desired for everyone. It costs a significant amount of $ but so do suspension hardware changes.
Cuzoe
@jamstonmartames You need firmware and dataset to match, whether it's B or C. This won't work...
Also, if you are going to load "C" firmware and dataset you have to make driving profile data set changes in your gateway to match. The "C" setup expects the gateway to send settings from 1-15. The "B" setup expects 1-3 (comfort, normal, sport).
If your gateway is sending 1-3 and your firmware expects 1-15 you are not going to have different mode effectively. From what I have read you basically get stuck in (varying levels of) sport.
There are no "C" data sets for the Golf/R. I'm running an Arteon dataset. I have absolutely zero complaints. But if you have your heart set on running a Golf R dataset then you need to stay with firmware B. Do you know for sure the R dataset is different from the FWD Golf dataset? The difference in weight is like having a small passenger in the back, not significant.
jamstonmartames
North East
GOLF 7.5
So springs may be different colour markings to that of GTI as well as how the rears should react when haldex is being engaged in the corners.
Thanks for the advice on staying clear of the C Variant in this specific case.
With regards to the parameter file itself, I can't even find anything for module 14 on any car, let alone a mk7 gti. :( Any hints? I've got Parameters for every other module going apart from 14.
Cuzoe
Springs will be different for sure. They are even different for Manual/DSG. And I understand that VW will have different part numbers for the dampers between GTI/R. But most (aftermarket) companies spec the same dampers for the Golf/R, while the springs are spec'd differently for the specific weight of each vehicle.
I'm just not sure about the DCC parameters. It's also possible that a single parameter contains data for both the GTI/R and that the module selects tables based on the VIN. Sure the DCC module might preemptively stiffen the rear as Haldex is engaged, but that's speculation. When the car's weight shifts the rears will stiffen anyway.
jamstonmartames
North East
GOLF 7.5
Ok I've created a starter for ten:
The start address given I've kicked off the dataset from the first digit should be 1 right?
<MESSAGE DTD="XMLMSG" VERSION="V0.1">
<RESULT>
<RESPONSE NAME="GetParametrizeData" DTD="RepairHints" VERSION="1.4.0.0" ID="0">
<DATA>
<PARAMETER_DATA DIAGNOSTIC_ADDRESS="0x14" START_ADDRESS="" PR_IDX="0" ZDC_NAME="5Q0907376B" ZDC_VERSION="0204" LOGIN="20103" LOGIN_IND="">0x4D,0x39,0x30,0x30,0x64,0x0A,0x00,0x0A,0x00,0x01,0x01,0x32,0x0F,0x01,0xF4,0x06,0x00,0x00,0x07,0x02,0x00,0x00,0x14,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x22,0x22,0x33,0x44,0x55,0x03,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x11,0x22,0x33,0x00,0x55,0x66,0x00,0x00,0x55,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x20,0x20,0x20,0x20,0x20,0x20,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x0B,0x0B,0x05,0x02,0x05,0x0B,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x21,0x24,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x05,0x02,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x40,0x1C,0x00,0x00,0x20,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x1E,0x00,0x1E,0x00,0x10,0x00,0x12,0x04,0x12,0x00,0x37,0x00,0x17,0x00,0x06,0x00,0x07,0x00,0x12,0x00,0x1F,0x00,0x06,0x00,0x0E,0x00,0x06,0x00,0x0A,0x00,0x0A,0x00,0x7E,0x00,0x7F,0x00,0x0A,0x00,0x17,0x00,0x07,0x00,0x0A,0x00,0x0A,0x00,0x07,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFF,0xFE,0xFF,0xFE,0x00,0x01,0xFF,0xFE,0xFF,0xFE,0x00,0x6E,0x00,0x2E,0x00,0x0C,0x00,0x0E,0x00,0x24,0x00,0x3E,0x00,0x0C,0x00,0x0C,0x00,0x0C,0x00,0x04,0x00,0x04,0x00,0x24,0x00,0xFE,0x00,0x04,0x00,0x04,0x00,0x04,0x00,0x14,0x00,0x14,0x00,0x0E,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x02,0x02,0x00,0x02,0x0B,0x02,0x02,0x02,0x02,0x02,0x02,0x02,0x02,0x02,0x02,0x02,0x02,0x02,0x02,0x02,0x02,0x02,0x02,0x02,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x02,0x03,0x04,0x05,0x06,0x07,0x00,0x00,0x00,0x00,0x00,0x01,0x02,0x03,0x04,0x05,0x06,0x07,0xFF,0xFF,0xFF,0xFF,0xFF,0x00,0xFF,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x02,0x01,0x02,0x01,0x02,0x01,0x02,0x02,0x02,0x02,0x02,0x02,0x01,0x02,0x01,0x01,0x02,0x02,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x02,0x02,0x02,0x02,0x02,0x02,0x02,0x02,0x02,0x02,0x02,0x02,0x02,0x02,0x02,0x02,0x02,0x02,0x02,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x03,0x03,0x03,0x03,0x02,0x03,0x03,0x03,0x03,0x02,0x02,0x03,0x03,0x02,0x03,0x03,0x02,0x02,0x03,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x04,0x02,0x02,0x01,0x02,0x02,0x02,0x04,0x02,0x04,0x04,0x04,0x04,0x04,0x02,0x04,0x02,0x04,0x02,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x05,0x09,0x02,0x02,0x05,0x05,0x02,0x02,0x02,0x02,0x02,0x05,0x05,0x02,0x05,0x05,0x02,0x02,0x02,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x06,0x06,0x06,0x06,0x02,0x03,0x00,0x00,0x06,0x02,0x02,0x06,0x06,0x02,0x06,0x06,0x02,0x02,0x03,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x02,0x02,0x02,0x02,0x02,0x02,0x02,0x02,0x02,0x02,0x02,0x07,0x07,0x02,0x02,0x02,0x02,0x02,0x02,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x21,0x24,0x05,0x07,0x08,0x09,0x0B,0x0E,0x15,0x1C,0x2C,0x4B,0x0C,0x17,0x16,0x23,0x2E,0x2D,0x36,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x04,0x00,0x02,0x00,0x04,0x00,0x02,0x00,0x04,0x00,0x02,0x00,0x04,0x00,0x00,0x00,0x04,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x04,0x00,0x04,0x00,0x04,0x00,0x04,0x00,0x04,0x00,0x04,0x00,0x04,0x00,0x00,0x00,0x04,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x08,0x00,0x08,0x00,0x08,0x00,0x08,0x00,0x04,0x00,0x08,0x00,0x08,0x00,0x00,0x00,0x08,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x10,0x00,0x04,0x00,0x04,0x00,0x02,0x00,0x04,0x00,0x04,0x00,0x04,0x00,0x00,0x00,0x04,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x20,0x02,0x00,0x00,0x04,0x00,0x04,0x00,0x20,0x00,0x20,0x00,0x04,0x00,0x00,0x00,0x04,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x40,0x00,0x40,0x00,0x40,0x00,0x40,0x00,0x04,0x00,0x08,0x00,0x40,0x00,0x00,0x00,0x40,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x6E,0x02,0x4E,0x00,0x4C,0x00,0x4E,0x00,0x24,0x00,0x6E,0x00,0x0C,0x00,0x0C,0x00,0x4C,0x00,0x14,0x00,0x14,0x00,0x00,0x00,0x00,0x00,0x14,0x00,0x0E,0x02,0x4E,0x00,0x14,0x00,0x14,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x00,0x00,0x00,0x00,0x01,0x00,0x00,0x00,0x00,0x01,0x00,0x00,0x00,0x00,0x03,0x00,0x00,0x00,0x00,0x00,0xFF,0xFF,0xFF,0xFF,0x05,0x00,0x00,0x00,0x01,0x00,0x00,0x00,0x02,0x00,0x00,0x00,0x03,0x00,0x00,0x00,0x06,0x00,0x00,0x00,0x04,0x00,0x00,0x00,0x07,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x02,0xFF,0xFF,0xFF,0x00,0x02,0x00,0x00,0x00,0x00,0x00,0x00,0xFA,0x00,0x00,0x00,0x00,0x03,0x05,0x02,0x00,0x01,0xF1,0xF1,0x00,0x00,0x00,0x00,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x2E,0x00,0x01,0x02,0x03,0x04,0x05,0x07,0x06,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x02,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x00,0x05,0x00,0x00,0x00,0x01,0x00,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x10,0x10,0x00,0x10,0x00,0x10,0x00,0x00,0x00,0x00,0x00,0x00,0x10,0x00,0x10,0x10,0x00,0x00,0x10,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x32,0x32,0x32,0x32,0x02,0x32,0x32,0x32,0x32,0x02,0x02,0x32,0x32,0x02,0x32,0x32,0x02,0x02,0x32,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x54,0x50,0x00,0x00,0x50,0x50,0x04,0x04,0x00,0x04,0x04,0x54,0x54,0x04,0x50,0x54,0x04,0x04,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x06,0x06,0x03,0x03,0x00,0x03,0x00,0x00,0x03,0x00,0x00,0x76,0x76,0x00,0x03,0x03,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x98,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x03,0x01,0x02,0x12,0x4C,0x0A,0x14,0x05,0x07,0x08,0x09,0x0B,0x0E,0x15,0x1C,0x2C,0x4B,0x0C,0x17,0x16,0x23,0x2E,0x2D,0x36,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x01,0x01,0x01,0x01,0x02,0x02,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x7F,0x05,0x04,0x0F,0x03,0x1D,0x0E,0x01,0x0C,0x08,0x12,0x0D,0x0A,0x0B,0x09,0x02,0x16,0x1C,0x10,0x19,0x06,0x18,0x1B,0x1A,0x19,0x00,0x00,0x00,0x00,0x00,0x00,0x05,0x04,0x0F,0x03,0x03,0x0E,0x01,0x0C,0x08,0x12,0x0D,0x0A,0x0B,0x09,0x02,0x16,0x1C,0x10,0x19,0x06,0x18,0x1B,0x1A,0x17,0x00,0x00,0x00,0x00,0x00,0x00,0x02,0x02,0x02,0x03,0x03,0x03,0x03,0x03,0x03,0x03,0x03,0x03,0x03,0x03,0x03,0x03,0x03,0x03,0x03,0x03,0x03,0x03,0x03,0x03,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x00,0xFF,0x00,0x00,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x00,0xFF,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFF,0xFF,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFF,0xFF,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x00,0x00,0x00,0xF1,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFF,0xFF,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFF,0xFF,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x00,0x00,0x00,0xF1,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x02,0x03,0x04,0x05,0x07,0x06,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x02,0x19,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x8D,0x3C,0x19,0x11</PARAMETER_DATA>
</DATA>
</RESPONSE>
</RESULT>
</MESSAGE>
jamstonmartames
North East
GOLF 7.5
So an alternate file setup that I found with only seat files for the B variant
Do you remember your GTI dataset looking anything like this from formatting to the nomenclature?
Cuzoe
I couldn't begin to say what is inside the dataset for the DCC module. I can't say I'm that interested even now, haha. I never saw the GTI dataset. I just wanted to get it from a trusted source and not spend a lot of time for not much benefit, even if it meant paying an hour for someone to load it up for me (which is what I did for B dataset).
When I flashed the Arteon dataset I also didn't look at it. No reason really since there is not (to my knowledge) a template out there to parse the data. Even if I had two datasets to compare the difference wouldn't mean much without knowing the values of a given value.
Cuzoe
That's pretty cool. I do think it deserves it's own thread and/or GitHub. I would bet there are people that would be very interested in that, but already have DCC so might never read this thread. I'll follow the progress wherever you decide to track it.
jamstonmartames
North East
GOLF 7.5
Ok. All solved. the dataset for my golf was only obtainable from the VAG servers so finding a car which had the same spec was the only way to get the dataset for a 4 door hatchback, 4motion golf r. Having reviewed the parameters across the Seat Leon, The Cupra Variants, a VW Touran, a golf and a golf R, every single one is different (as you'd hope it to be) so don't go writing parameters for the wrong car as it might just end up bottoming out at the wrong moment. Roads in Britain aren't so forgiving.
DCC parameters look to not only control roll, stability, under braking, cornering & acceleration across the modes but this impacts steering massively too.
Having checked 44, the steering feel is controlled by driving modes which resides ultimately in 19 Gateway. But 19 Gateway is also communicating with 14 Wheel Dampening.
There is a definite attribution to steering input in the parameter coding that I've seen. There are roughly 50 major differences across each model's parameter set. Will start a new thread on this when I have mroe info.
But thanks @Cuzoe and @Chillout for all your help!
Another output of this will be to debunk this marketing piece from VW around DCC......DCC Standard vs DCC R ??
Is that because sharing isn't permitted on here? I've got ODIS if that's what you were thinking was the hurdle?
Also, do you know if v0130 is the normal arteon DCC or the DCC R as per this link?
https://www.volkswagen-newsroom.com/en/dynamic-chassis-control-dcc-3949
"The most advanced Dynamic Chassis Control (DCC) system currently available is installed on the Arteon. The system is available in two variants, the standard version with a specially balanced blend of driving comfort and dynamics, and a sports version, the DCC R. Although it also offers high levels of comfort, the balance of the sports version has been shifted slightly towards sporty performance. Both versions allow the adaptive dampers to be controlled via conventional driving profile selection (Comfort, Normal and Sport) and, for the first time, with infinitely variable settings over an extended range using a slide control in the individual setting menu (Comfort+ to Sport+)"
jamstonmartames
North East
GOLF 7.5
Just another thought to this, is that you could even use the Arteon c variant flash file on 14 Wheel Dampening and then get golf mk8 DCC datasets to make it work correctly for a car that;s roughly the same dimensions, weight, FWD/AWD etc...
Cuzoe
If by "work correctly" you mean marginally (but not likely to be noticeable) better than it works now... not worth my time 😂. It works great as is. Comfort++ is cushy, I assume Sport++ is quite stuff, and I'll never use it, haha.
I meet t knew what DCC standard vs DCC R meant. But I would expect the same DCC hardware. Possibly slight DCC dataset tuning changes in the Sport mode 🤷🏿‍♂️. Would be similar to VW offering the Sport suspension package on a Golf, which could be just slightly shorter/stiffer springs, except with DCC it's all the same physical equipment.
