Daytime Running Lights (DRL) not working
dfw_gti
DFW, TX
Hi Everyone
Brand new member here looking for an easy fix (fingers crossed).
I just got a 2015 GTI with Lighting Package. I can't get the DRLs to turn on and I am getting a dash light and warning to "Check Left/Right DRL". I know everyone on this forum wants them off, but I like the way they look and I really just want this stupid dashlight off. I've been too busy to really dive in and try to troubleshoot but if anyone has had this problem please let me know if there is a simple fix. If there is no simple fix, please recommend the main things to check (fusebox, etc.). I haven't opened up the headlamps so I am not even sure if these DRLs have regular bulbs? Maybe both of them just burnt out?
Anyway, any help is greatly appreciated for when I try to figure this out tonight! Thanks!
dfw_gti
DFW, TX
Right?! I was just reading people like to turn them off with OBDeleven.
But no like I said I haven't really been able to look at them. I just got the car on Sunday and I will investigate further tonight. But when I do, it appears I will have to pull the bumper off and pull the headlight housing out since I have the xenon headlights. Is that a correct assessment?
david9962000
Los Angeles, CA
MK7 GTI
I don't think there is a bulb for the DRL, only for the low/high beam.
I turned mine off because my GTI is red and I live in SoCal. If it was a dark color they would be on.
dfw_gti
DFW, TX
Yeah I agree, they look better on dark cars.
And I assumed there was no bulb too, though I've never messed with lights like these before. Do you know if there is any part of the DRL/headlight I could replace to see if it would fix the issue?
The Fed
Old Guys Rule
Florida
There's no replaceable bulbs. If they're bad you need new headlight assemblies. Were they working when you bought the car?
nype
Vancouver, B.C.
^ this
They’re likely setup to both disable when one malfunctions so that there isn’t just one running at a time. The cornering bulbs do this as well, I believe.
southpawboston
Somerville, MA
I am so glad I don't have LP with LED DRLs. I can't fathom the idea of having to replace an entire headlamp unit if one LED goes.
Remember that whole Golf Mk5 LED third brake light debacle? "But LEDs will never burn out". LOL.
dfw_gti
DFW, TX
Yes they were out when I bought it. You’re probably right that they both go out if one does. It just seems pretty ridiculous that I would have to replace the entire headlight for just a bad DRL. Thanks VW for making that as easy as possible...
The Fed
Old Guys Rule
Florida
There's a lesson in here somewhere...
Adurm
Fl
Tried scrolling through your radio for light settings? I have drl on or off option i coded. Never threw a check bulb light though.
dfw_gti
DFW, TX
No the U will not come on at all. I haven't found a way to replace the LEDs so I was going to try replacing the ballasts first.
