Dash lit up like a Christmas tree, all errors under the sun. Turned off car, now it won't start. Turns on, but immediately turns off. Immobilizer?
GTI Jake
Charlotte, NC
Yes. Keys still lock/unlock the doors.
One thing I just mentioned to him I noticed in the video, is the digital dash doesn't load the milage.
Mine does that pretty much instantly the second it kicks on.
Thats not a good sign, I’m not in my car but just having the door open should display the mileage IIRC.
Dash is a lot more expensive/time consuming swap than a start stop switch, but that makes the dash look more suspicious.
Acadia18
2019 Golf R
So it doesn't do it the moment you open the door on this dash, but it should load up when you press the ignition to turn on the accessory power without turning the car on. I have the same dash (installed at the same time), and that's how mine behaves.
I recommend to him to swap the original unit back in. It's a bit of a pain, but no more than an hour or so of work.
GTI Jake
Charlotte, NC
In that case the switch is still my top pick.
The power on functions aren’t matching switch position.
Acadia18
2019 Golf R
Do you mean the actual physical push to start button/switch itself? That'd be a quick 5 minute swap to try plopping mine in his car that wouldn't hurt to try.
Unless you're talking about the BCM (BCM might not be the right term) that the switch connects to that actually controls those functions once you press the button? That might be a little more challenging...
GTI Jake
Charlotte, NC
Yeah the push to start switch itself
Acadia18
2019 Golf R
Almost has to be the display.
This is such a weird issue I can't get behind "Almost has to be..." for any suggestion. But also wouldn't rule anything (that hasn't been tried yet) out.
It's just a very inconvenient time. I think he plans on trying to put the original dash back in, but just tough finding the time 3 days before Christmas.
Acadia18
2019 Golf R
Fliptrocity
RI
8v S3 | B9 A4
Fuel pump still primes when i open the door.
Going to try the cluster swap back to OEM and see how that goes.
Push button not matching positioning is a possibility but less likley given how the whole thing first manifested itself in the middle of my commute to work this morning. Car was driving normally, no limp mode or anything like that. Codes you see in the video popped while i was driving and the radio shut off (still turns on just fine now) but the radio does say that in order to make any changes in the car settings page that the ignition has to be on - and no matter the sequence of of push to start pushes with and without clutch depressed, it continues to report the ignition as not on.
GTI Jake
Charlotte, NC
The dash shouldn’t have any control over the radio turning off and on, or the car cranking but not starting.
Rule out the push to start switch before you dive into taking the dash out.
Acadia18
2019 Golf R
Update - He went down to try to fiddle with the push button start like @GTI Jake was talking about.
Car randomly started fine, no issues. Drove it around, drives fine.
Got back home, did an OBD11 scan with the car running. Bunch of databus errors.
Cleared codes, everything looks fine. Turned it off and back on again fine.
Scan results below.
OBDeleven data log
Date: 2021-12-21 22:04
VIN: 3VW547AU9HM055332
Car: Volkswagen Golf GTI
Year: 2017
Body type: 5-dr hatchback
Engine: CXCB
Mileage: 75969 KM
01 Engine
System description: 2.0l R4 TFSI
Software number: 5G09C0BB01
Software version: 0001
Hardware number: 06K907425B
Hardware version: H13
ODX name: EV_ECM20TFS0205G09C0BB01
ODX version: 001003
Long coding: 091900122444002F1000
Trouble codes:
null - Unknown
static
null - Unknown
Intermittent
null - Unknown
Intermittent
null - Unknown
Intermittent
null - Unknown
Intermittent
null - Unknown
Intermittent
null - Unknown
Intermittent
null - Unknown
Intermittent
null - Unknown
Intermittent
null - Unknown
Intermittent
03 Brakes
System description: ESC
Software number: 5Q0614517AQ
Software version: 0400
Hardware number: 5Q0614517AF
Hardware version: H62
Serial number: 50487000001046
ODX name: EV_Brake1UDSContiMK100ESP
ODX version: 036010
Long coding: 01FA6BA154250971407A020340C56880D62A900240021636144350D1C089430000000012121212B835351919323200
Trouble codes:
U140000 - Function restriction due to insufficient voltage
Intermittent
B116816 - Steering angle sensor Voltage too low
Intermittent
U112100 - Databus missing message
Intermittent
Intermittent
Intermittent
Intermittent
Intermittent
Intermittent
Intermittent
Intermittent
Intermittent
Intermittent
Intermittent
Intermittent
Intermittent
Intermittent
Intermittent
Intermittent
Intermittent
Intermittent
C102D00 - Tire pressure warning
Intermittent
C114602 - Tire pressure monitoring display Signal error
Intermittent
Intermittent
Intermittent
Intermittent
08 Air Conditioning
System description: Climatronic
Software number: 5GM907044E
Software version: 1801
Hardware number: 5GM907044E
Hardware version: H04
ODX name: EV_ACClimaBHBVW37X
ODX version: 006145
Long coding: 00020014200100000004000012111402
Trouble codes:
Intermittent
Intermittent
09 Central Electrics
System description: BCM PQ37BOSCH
Software number: 5Q0937087AN
Software version: 0223
Hardware number: 5Q0937087AN
Hardware version: 032
Serial number: C864100317009Z
ODX name: EV_BodyContrModul1UDSBosc
ODX version: 017002
Subsystems:
System description: WWS 170106
Software version: 0551
Hardware version: 043
Serial number: 97022066170123111021
Long coding: 0E4DDD
System description: RLHS
Software version: 0105
Hardware version: 042
Serial number: S4Y17M01D19H15M21S00
Long coding: 06A8DD
System description: J245 PS60.006
Software version: 0170
Hardware version: H07
Serial number: 03690829300111162129
Long coding: 181803
Trouble codes:
U101100 - Supply voltage Voltage too low
Intermittent
Intermittent
Intermittent
Intermittent
Intermittent
Intermittent
Intermittent
Intermittent
Intermittent
Intermittent
Intermittent
Intermittent
Intermittent
Intermittent
Intermittent
Intermittent
Intermittent
Intermittent
Intermittent
B12CA01 - License plate lamp Electrical error
Intermittent
B147918 - Remote key 1 Voltage too low
Intermittent
B12DB29 - Lock unit for central locking, rear, left Implausible signal
Intermittent
B12DC29 - Lock unit for central locking, rear, right Implausible signal
Intermittent
13 Adaptive Cruise Control
System description: ACC BOSCH MQB
Software number: 5Q0907572H
Software version: 0620
Hardware number: 5Q0907572H
Hardware version: H10
ODX name: EV_ACCBOSCHVW416
ODX version: 002005
Long coding: 2D00008141FFC428949C810510301600000000000000000000
Trouble codes:
U112300 - Databus error value received
Intermittent
Intermittent
Intermittent
Intermittent
Intermittent
Intermittent
Intermittent
Intermittent
Intermittent
Intermittent
14 Wheel Dampening
System description: DAEMPFUNGS-SG
Software number: 5Q0907376B
Software version: 0121
Hardware number: 5Q0907376A
Hardware version: H17
Serial number: 20011741350123
ODX name: EV_DRCONTITEMIC
ODX version: 001019
Trouble codes:
Intermittent
Intermittent
Intermittent
Intermittent
15 Airbag
System description: AirbagVW20
Software number: 5Q0959655J
Software version: 0830
Hardware number: 5Q0959655J
Hardware version: 010
Serial number: 003GCR07B5WR
ODX name: EV_AirbaVW20SMEVW37X
ODX version: 002144
Long coding: 8CCCFC00000000005000001AC24800000065
Subsystems:
System description: BF-Gewichtss.
Software version: 0022
Serial number: IBH000000000006QVG0$
Long coding: 303131
System description: SideSensor_Df
Software version: 0887
Hardware version: 001
Serial number: 357000000000FB68112G
Long coding: 2D2D2D
System description: SideSensor_Pf
Serial number: 35800000000092683023
Long coding: 2D2D2D
System description: SideSensor_Dr
Software version: 6149
Hardware version: 000
Serial number: 3510001C32404064D4BU
Long coding: 2D2D2D
System description: SideSensor_Pr
Serial number: 3520001BF2404031C26S
Long coding: 2D2D2D
System description: FrontSensor_D
Serial number: 3550002BF2439CA351EI
Long coding: 2D2D2D
System description: FrontSensor_P
Serial number: 3560002C323E4841D172
Long coding: 2D2D2D
Trouble codes:
B10B200 - Function restriction of seat occupied recognition due to missing message
Intermittent
B13BCF2 - Multiple collision brake No function
Intermittent
U110100 - Component protection active
Intermittent
Intermittent
Intermittent
Intermittent
Intermittent
Intermittent
Intermittent
Intermittent
Intermittent
Intermittent
B10B400 - Function restriction of seat occupied recognition due to undervoltage
Intermittent
16 Steering Column
System description: Lenks. Modul
Software number: 5Q0953507HL
Software version: 0140
Hardware number: 5Q0953549E
Hardware version: 003
Serial number: 16111608491437
ODX name: EV_SMLSKLOMQB
ODX version: 020002
Long coding: 0400
Trouble codes:
Intermittent
Intermittent
17 Dashboard
System description: KOMBI
Software number: 5G1920856B
Software version: 8311
Hardware number: 5G1920856B
Hardware version: 344
ODX name: EV_DashBoardVDDMQBAB
ODX version: 009051
Long coding: 0BAD0912BD88CF0502886A095000000000000000
Trouble codes:
Intermittent
Intermittent
Intermittent
Intermittent
Intermittent
Intermittent
Intermittent
Intermittent
Intermittent
Intermittent
Intermittent
Intermittent
Intermittent
19 Gateway
System description: GW MQB High
Software number: 3Q0907530C
Software version: 5286
Hardware number: 3Q0907530C
Hardware version: 515
Serial number: 04031700840003
ODX name: EV_GatewNF
ODX version: 013020
Long coding: 0101000870085900FB00023B880F00000001050000000000000000000000
Subsystems:
System description: E221__MFL-DC1
Software version: 0040
Hardware version: H11
Serial number: 29170000020910067034
Long coding: 34FFFF
Trouble codes:
No trouble codes found
2B Steering Column Lock
System description: ELV-MQBA
Software number: 5Q0905861A
Software version: 0120
Hardware number: 5Q0905861A
Hardware version: H01
Serial number: 17000067985008
ODX name: EV_ELVMarquMQB
ODX version: 004111
Long coding: 5500000000000000
Trouble codes:
Intermittent
Intermittent
Intermittent
Intermittent
Intermittent
Intermittent
Intermittent
Intermittent
Intermittent
32 Lock Electronics
System description: Quersperre
Software number: 0CQ907554E
Software version: 8042
Hardware number: 0CQ907554E
Hardware version: H52
Serial number: HA1-00003.12.1600011510
ODX name: EV_LockElectHA1VW37X
ODX version: 001007
Long coding: 0001
Trouble codes:
Intermittent
Intermittent
Intermittent
Intermittent
Intermittent
Intermittent
Intermittent
Intermittent
3C Lane Change Assistant Right
System description: HRE_Master
Software number: 5Q0907686B
Software version: 0071
Hardware number: 5Q0907686B
Hardware version: H12
Serial number: 0431039345
ODX name: EV_HREntryHella
ODX version: 001028
Long coding: 01011103
Trouble codes:
Intermittent
Intermittent
U004700 - Vehicle Communication Bus C Performance
Intermittent
C1190F2 - Blind spot recognition ctrl. module 2 Function limitation due to insufficient voltage
Intermittent
42 Driver Door
System description: TSG FS
Software number: 5Q0959593E
Software version: 0041
Hardware number: 5Q0959593B
Hardware version: 020
Serial number: 0303170605002N
ODX name: EV_DCUDriveSideEWMAXKLO
ODX version: 006003
Long coding: 003E13200000020000000000
Subsystems:
System description: Fond FHSG DRV
Software version: 0002
Hardware version: 007
Serial number: 00000000000005905403
Long coding: 011000
Trouble codes:
Intermittent
B11FD13 - Turn signal in exterior rear-view mirror Open circuit
Intermittent
Intermittent
Intermittent
Intermittent
Intermittent
B131FF5 - Rear window regulator, driver side Voltage supply lower limit not reached
Intermittent
44 Steering Assistance
System description: EPS_MQB_ZFLS
Software number: 3QM909144
Software version: 5072
Hardware number: 3QM909144
Hardware version: 506
ODX name: EV_SteerAssisMQB
ODX version: 013144
Long coding: 8102
Trouble codes:
B1168F2 - Steering angle sensor no initialization
Intermittent
Intermittent
Intermittent
Intermittent
Intermittent
Intermittent
Intermittent
Intermittent
52 Passenger Door
System description: TSG BFS
Software number: 5Q0959592E
Hardware number: 5Q0959592B
Serial number: 070317060502KN
ODX name: EV_DCUPasseSideEWMAXKLO
ODX version: 006003
Long coding: 003E13200C00020000000000
Subsystems:
System description: Fond FHSG PSG
Serial number: 00000000000005470741
Long coding: 091000
Trouble codes:
Intermittent
Intermittent
Intermittent
Intermittent
Intermittent
Intermittent
B1320F5 - Rear window regulator, front passenger side Voltage supply lower limit not reached
Intermittent
55 Headlight Regulation
System description: AFS-ECU
Software number: 7P6907357D
Software version: 0090
Hardware number: 7P6907357A
Serial number: --------------
ODX name: EV_HeadlRegulVWAFSMQB
ODX version: 001120
Long coding: 021203010B000400
Subsystems:
System description: LeiMo links
Software version: 0004
Long coding: 2E0000
System description: LeiMo rechts
Long coding: 2E0000
Trouble codes:
Intermittent
Intermittent
C108116 - Left headlamp power output stage Voltage too low
Intermittent
C108216 - Right headlamp power output stage Voltage too low
Intermittent
U120100 - Data bus No communication
Intermittent
U112200 - Databus implausible message
Intermittent
Intermittent
5F Multimedia
System description: MU-S-NS-US
Software number: 3Q0035876A
Software version: 0753
Hardware number: 3Q0035876A
Hardware version: 840
ODX name: EV_MUStd4CDELP
ODX version: 001001
Long coding: 027300020000000051220002001808009F0203F401200105C6
Subsystems:
System description: ABT_Std-2_Nav
Software version: 8130
Serial number: VWZ6ZHV2680558
System description: NAR 2017
Software version: 0525
Hardware version: ---
Serial number: --------------------
Trouble codes:
B201A00 - Checking software version management
static
B11CF53 - Tuner for satellite radio Deactivated
static
B105413 - GPS antenna Open circuit
static
75 Telematics
System description: OCULowMQBUS
Software number: 5QE035285A
Software version: 0570
Hardware number: 5QE035285A
ODX name: EV_OCULowMQB
ODX version: 001006
Long coding: 02730002C2823A017F1E06000000
Trouble codes:
Intermittent
Intermittent
Intermittent
Intermittent
Intermittent
Intermittent
Intermittent
Intermittent
Intermittent
A9 Structure Borne Sound
System description: SAS-GEN 2
Software number: 5G0907159
Software version: 0014
Hardware number: 4H0907159A
Hardware version: H06
Serial number: 161128201890
ODX name: EV_SoundActuaGen2AU64X
ODX version: 003010
Trouble codes:
Intermittent
Intermittent
U10D900 - Incorrect vehicle type
Intermittent
Intermittent
B7 Start System Interface
System description: VWKESSYMQB
Software number: 5Q0959435B
Software version: 0710
Hardware number: 5Q0959435
Hardware version: 021
Serial number: 0430169508
ODX name: EV_KessyHellaMQBAB
ODX version: 002019
Long coding: 032C0C
Trouble codes:
Intermittent
Intermittent
Intermittent
Intermittent
Intermittent
Intermittent
Intermittent
Intermittent
Acadia18
2019 Golf R
Just to be clear, he didn't do anything. Nothing was changed, the car just decided now to start fine. Jake talking about the button did prompt him to go down to the car and check it out, so that credit is due. But just out of nowhere, car said "Aight, I'm good."
So messing with the button was probably coincidental?
