southpawboston
- Somerville, MA
I know many people have installed dash cams and hardwired them to the fuse box.
I don't want to run a wire down to the fuse box. I'd prefer to tap into existing power at the overhead console. Has anyone done this?
If I'm reading the wiring diagram correctly, there is a 6-pin connector that supplies power and ground (programmed ground from the BCM) to the overhead lights. Pin 1 provides constant 12V while pin 6 provides ground from the BCM whenever the car is switched on, and for 10 minutes after key off. That would work out okay for me.
Just wanted to know if anyone has attempted this.
