BronxBomber
- Orlando,FL
Thread Revival ?They're very similar. The wiring is the same with the exception of PR adding ethanol content sensor wiring direct to the ECU. Other than that the harness is identical.
Haven't verified the injector part number, but Bosch doesn't even make a 920cc Injector so it has to be the same one. There is no other similar size in that product line.
The CTS kit uses a different fuel flow loop, but it doesn't seem to make any difference. If you don't like the way they do it, a $15 fitting is all you need to do it the same way as PR.
The CTS kit has much nicer inserts, and actually has clips that lock the injectors into the rail. The PR kit has inserts known to fail and nothing to hold the Injector in the rail if they do fail.
As for flow matching, it can't hurt but these are Bosch Injectors, not Chinese mystery junk. They will be pretty consistent from the factory.
Have the CTS, no issues. Recommend a euro manifold because then the MPI kit drops right in and saves a lot of time and hassle. Also, don't waste your money on 1300cc injectors unless you have a much bigger turbo and a built motor in your future.
Hey Hoon. I really want to run full E85. I’ve had the PR fuel lines for a year just sitting in my garage since I have the CTS MPI kit and it doesn’t play nice with the CTS fuel rail. Could you point me in the direction of the $15 fitting that will make them play nice together? Appreciate it.
