JerseyDrew77
- Virginia & NC
- 2016 TR GTI S 6MT
I know there are only a few of us that have MPI for our cars so looking for those that have one or the other and what are your thoughts on installation and overall performance. I've heard issues with the PR one and their injectors not staying in place and the CTS one is slightly cheaper but I don't care for it's design.
CTS
https://www.ctsturbo.com/product/cts-turbo-mk7-vw-audi-ea888-gen-3-port-injection-kit/
Features:
- Proprietary billet aluminum high-flow fuel rail (hard anodized for E85 fuel).
- 980cc (up to 500hp) or 1300cc (500hp and up) Bosch injectors.
- Installs like factory-designed MPI for maximum functionality.
- OEM fuel pressure sensor.
- Complete wiring harness for factory ECU integration.
- Installation hardware included.
- Eliminates the need to clean intake valves.
Precision Raceworks
http://www.precisionraceworks.com/index.php?route=product/product&path=20_61&product_id=103
Features:
- 925cc (500 whp) or 1300cc (700+ whp) Bosch injectors.
- Billet aluminum fuel rail (features large AN6 input and output port and will
not crack and leak like plastic fuel rails available from ROW cars).
- Fully Ethanol / E85 compatible injectors, fuel rail, fuel sensor, and other
hardware.
- Factory ECU integration (the included plug and play harness connects to all
required sensors and injectors and pins directly into the ECU connector and
fuse box).
- All necessary mounting hardware is included and meet or exceed OEM
requirements to ensure your kit will fit, look, and function for years to
come.
Precision Raceworks also mentions that their Bosch injectors are flow matched by an outside lab and come with detailed certification giving you all the flow data needed for optimal tuning. In addition, the included injectors have a spray pattern which has been modified to their proprietary specs designed specifically for the EA888 engine as off the shelf injectors and those offered by other companies have wide spray patterns that have been known to cause damage to the engines.
CTS
Features:
Precision Raceworks
Features:
hardware.
fuse box).
come.
