Ital
- Italian in CT
I have OBD11 as well, how do I check?
In the engine control module, scroll down and you'll see "Readiness".I have OBD11 as well, how do I check?
hmm, i have apr downpipe with race cat for over two years now with a spacer and no cell.
I am assuming I have achieved reediness by now, but how do I check to make sure?
When I check the codes I do get some type of warning about the cat, like not able to sniff the fumes or something to that regards..., but since I have no check engine light I figure it is fine...
I am still about one year away to emissions... just do not want any surprises.
Thanks
Do you have a tune at all?ok so I checked for Readiness, and everything says, "completed successfully", but:
"Number of emission-relevant DTC memory entries" - 0
"Malfunction indicator lamp" - OFF
"Monitoring of catalytic converter at operating temperature" - Not activated
I did this while the car was off, not sure if I should check while it is on.
Based on the above, does it look like I would pass emission?
Thank you
Is that test pipe tune or non test pipe tune? The Not available monitoring at operating temp is the only one I have not ready also. But it could mean it's not something that's done on our cars and we will pass. I compared a stage 1 map to my stage 2 map and made the emissions tables match so I think we have everything set right to pass.Yes apr stage 2
I'm due end of November. I guess I will be your test mule. I wish I had screen capped my readiness screen when I had an APR Stage 1 tune with my stock DP.I have the non test pipe tune, thus I needed the spacers. I think we will pass then fingers cross.
when is emission due for you? Mine is next March
My current screen. I hope this means I'll pass.
Didn't go yet. I'll update when I do. It's gotta be done by the end of the month.Did you pass yet?
Curious as I have a CTS catted DP with a CEL, but emissions not due until July 2020. No tune yet.
BTW, my readiness screen matches the readiness of a stock Golf GTI. That not activated is normal.Did you pass yet?
