Sure.I do keep those things in my car. But it's because I'm in the car ten hours per day.
Your MPG after getting the Dragy
100% negative correlation of mpg to sending it...HAAHHAHAHAHAHAAHAYour MPG after getting the Dragy
Yes, I've watched their employees timing the pumps. The bad side is that the quick fill (high flow rate) doesn't agree with my non-VW wagon, so it keeps shutting off before full, even on the lowest flow rate.Another piece of trivia about Costco - they change their tank filters OFTEN and used to brag about it. 2 things happen - your gas pumps faster, and obviously having a clean, frequently-changed filter should do a better job keeping crap out of your tank. Ever fill up and get frustrated with a chronically-slow pump? That's the filter - way past due to be changed.
Plus they get multiple truckloads of fuel daily so it's always fresh.
Because you never wait because right side filling....those sides if the island are always empty. Because their gas is great and cheap AF.
Yep...science. Thing is most peeps don't know this so the lines on the left fill sides are long and the right side fill sides are empty most of the time. I never wait.Also - they've designed their islands to accommodate pulling in on either side. Hoses are long enough to reach across your car if you've gotten into the "wrong" (or faster) lane. Brilliant.
You don’t say...Driving into a stiff headwind will also kill mpg if all other variables remain the same.
You don’t say...
