Cosmetic issues
Tomass79
I slid into a snow bank last week and suffered some scratches. Any product anyone likes to use? I have tried the brush on paint and the pens in the past but I always thought it looked bad. I was thinking of taping up around the scratches real well and using a spray. Any thoughts? Also the headlight is scratched pretty deep. Any ideas on that? Thanks
snobrdrdan
former GTI owner
If they're not finger nail deep, they could/should buff out with some compound/polish.
Outside of that, you'd want it "professionally" repaired/resprayed to look right.
Your idea of taping it off and "using a spray" is the worst idea possible. You'd need to prep it properly and then blend it in, which is above a DIY level.
If it doesn't buff out, leaving it alone might be the best option (unless you want to get it all repainted). Other repairs might just stick out like a sore thumb/not look right, especially if you're sweating these little marks at the moment.
StorableComa
SoCal, USA
17 GSW S FWD
If you really are set on DIY, maybe look into Dr.Colorchip? I plan on using that over the pens unless I can find some of the bottle touch up paint, though that's mainly due to metal flake not flowing through the pens well for my color - don't think that'd be an issue for you.
Their paint kit seems pretty affordable and the video makes it look easy to blend.
Tomass79
Thanks. I will look into the colorchip option. I really only care so much about the one on the door panel as it is very noticeable. Any ideas on the headlight?
StorableComa
SoCal, USA
17 GSW S FWD
Could try one of the headlight refinish products meant to remove fogging/discoloration. They normally have an abrasive they have you wet sand the headlight with. Might help make them less noticeable.
