I need help diagnosing my vehicle's (2015 GTI CXCB) coolant bubbling issue.
Parts Replaced:
-thermostart housing [original vw]
-water pump [original vw]
-engine oil cooler [original vw]
-coolant hose adapters that connect to water pump (all three) [original vw]
Current Scenario:
1. I put the car back together after replacing the above parts. At this point the coolant system is mostly empty and I fill it up with distilled water.
2. I start the engine and at this point the reservoir contains clean distilled water.
3. Engine starts to reach temperature and settles at 90 degrees (celsius).
4. The HVAC is set to high, fan low. Vents blowing out normal air and not hot air.
5. Bubbles start to form in the coolant reservoir and after a few minutes some form of oil+water mixture starts to overflow out of the reservoir.
6. I turn engine off and immediately all the coolant (water+oil mixture) is sucked out of the reservoir. My assumption is that the coolant is going to the water pump.
7. Reservoir remains empty after engine has cooled (checked a few hours after).
8. The dipstick looks like clean oil and not a mixture of water/oil like the reservoir.
Diagnosis?
I have performed a coolant pressure test and it does hold pressure. At this point I can only think of two potential sources below.
i. Transmission Oil Cooler
ii. Engine (Head Gasket and/or Cracked Block/Head)
I did notice oil settled around the transmission oil filter but the transmission oil cooler itselt was clean and dry. This is problably a separate unrelated issue.
I am also thinking about bridging the coolant hoses connected to the transmission oil cooler to rule it out.
Question:
1. Does anyone know why the coolant bubbling and eventually mixing with oil only starts after the engine has reached operating temperature? I ask because if it is a head gasket issue wouldn't the bubbling begin immediately after the car is turned on and not after it has reached temperature, which is when the thermostat would open?
2. Any suggestion on what I can test for next?
Here is a picure of what the reservoir looks like when bubbling.
Thanks,
Parts Replaced:
Current Scenario:
Diagnosis?
Question:
Thanks,
