Posted these at the end of another thread so figured I'd post these if anyone needs to reference them.
Yes these cars have a complex ass cooling system. If anyone outside the US knows more about models lacking the V55 recirc pump I can update.
All 1.8T manuals and non high output 2.0T manuals
Has one extra electric water pump
1 - Radiator
2 - Engine Coolant Temperature Sensor on Radiator Outlet - G8
3 - Engine Temperature Control Adjusting Element - N493
4 - Cylinder Head/Cylinder Block
5 - Restrictor
6 - Parking Heater ❑ Equipped on some models
7 - Coolant Expansion Tank
8 - Coolant Expansion Tank Cap
9 - Check Valve
10 - Exhaust Manifold Integrated in cylinder head
11 - Turbocharger
12 - Heater Core for the Heater
13 - Restrictor
14 - Check Valve
15 - Heater Support Pump - V488
16 - Engine Coolant Temperature Sensor - G62
17 - Coolant Shut-Off Valve - N82
18 - Restrictor
19 - Coolant Pump
20 - Check Valve
Most 1.8T and 2.0T with DSG. USA models.
Has two electric water pumps. Some ROW 1.8T lack the V55 Recirc pump.
1 - Radiator
2 - Engine Coolant Temperature Sensor on Radiator G83
5 - Restrictor
9 - Check Valve
11 - Turbocharger
13 - Restrictor
14 - Check Valve
15 - Heater Support Pump - V488-
18 - Restrictor
19 - Recirculation Pump - V55
20 - Coolant Pump
21 - Transmission Coolant Valve - N488
22 - Check Valve
23 - Transmission Fluid Cooler
Certain ROW 2.0T DSG models. Often sold in 'Hot' climates. Also USA TT
Has an Aux Rad and 2 electric pumps
1 - Radiator
2 - Engine Coolant Temperature Sensor G83
5 - Restrictor
6 - Coolant Expansion Tank
7 - Coolant Expansion Tank Cap
8 - Check Valve
9 - Exhaust Manifold
10 - Turbocharger
11 - Heater Core
12 - Restrictor
13 - Check Valve
14 - Heater Support Pump - V488
15 - Engine Coolant Temperature Sensor - G62
16 - Coolant Shut-Off Valve - N82
17 - Restrictor
18 - Recirculation Pump - V55
19 - Coolant Pump
20 - Transmission Coolant Valve - N488
21 - Check Valve
22 - Transmission Fluid Cooler
23 - Auxiliary Radiator ❑ Installed location: inside the right front wheel housing
High output manual 2.0T such as Golf R.
Same as the other manual coolant diagram. Just with the Aux rad
1 - Radiator ❑ Installed location: inside the right front wheel housing
5 - Restrictor
8 - Check Valve
10 - Turbocharger
11 - Heater Core
12 - Restrictor
13 - Check Valve
17 - Coolant Pump
18 - Restrictor
19 - Check Valve
20 - Radiator
High output 2.0T w/DSG
Has two aux rads. Removes the DSG recirc pump, so only one electric water pump.
The DSG cooler feed also comes from the upper rad hose instead of off the water pump.
1 - Auxiliary Radiator ❑ Installed location: inside the right front wheel housing
5 - Restrictor
8 - Check Valve
10 - Turbocharger
11 - Heater Core
12 - Restrictor
13 - Check Valve
17 - Coolant Pump
18 - Restrictor
19 - Transmission Coolant Valve N488
20 - Transmission Fluid Cooler
21 - Aux Radiator ❑ Installed location: inside the left wheel housing
22 - Check Valve
23 - Radiator
So yes if you are curious it is possible to add the Right/Passenger side Aux radiator to any 1.8T or 2.0T. This radiator sits in parallel to the main rad, with the benefit of not being behind the AC condenser and intercooler.
For DSG models it is also possible to add in the Left/Driver side Aux radiator. Some cars might have a SAI system that is in the way though.
1 - Radiator
5 - Restrictor
9 - Check Valve
11 - Turbocharger
13 - Restrictor
14 - Check Valve
18 - Restrictor
19 - Coolant Pump
20 - Check Valve
1 - Radiator
5 - Restrictor
9 - Check Valve
11 - Turbocharger
13 - Restrictor
14 - Check Valve
18 - Restrictor
20 - Coolant Pump
22 - Check Valve
1 - Radiator
5 - Restrictor
8 - Check Valve
10 - Turbocharger
11 - Heater Core
12 - Restrictor
13 - Check Valve
17 - Restrictor
19 - Coolant Pump
21 - Check Valve
5 - Restrictor
8 - Check Valve
10 - Turbocharger
11 - Heater Core
12 - Restrictor
13 - Check Valve
17 - Coolant Pump
18 - Restrictor
19 - Check Valve
20 - Radiator
5 - Restrictor
8 - Check Valve
10 - Turbocharger
11 - Heater Core
12 - Restrictor
13 - Check Valve
17 - Coolant Pump
18 - Restrictor
22 - Check Valve
23 - Radiator
