Coolant completely gone after long drives
Stevied4952
Kent
Vw Golf Gtd Estate
Hi all wondered if any of you can help? Drove about 240 miles on holiday and coolant light came on after we got back into the car. Coolant was completely gone. Topped it up and was fine next few days as short journeys. Drove back home and same thing again - completely empty when home. Local Garage has looked at it and no visible signs of a leak. Any ideas?
tmw2442
Mk7 R
Usually dries white. I would assume the way you have described it's leaking from the pump underneath the intake manifold. How long/hard did the local garage look?
Stevied4952
Kent
Vw Golf Gtd Estate
Ahha cheers for that info, they had a pretty good look up on the ramp and all. Ill mention that to them when I take it back there 👍
misor1994
Slovakia
Golf GTD Variant
If they have an endoscope, tell them to check the internals of the intercooler in the front of the engine. It may be cracked inside where the coolant leaks then. It's quite common issue with TDI engines of this generation. Or just tell them to make a pressure test of the intercooler.
tmw2442
Mk7 R
would assume language barrier, assuming you mean radiator?
tmw2442
Mk7 R
