Charlotte.:R
- Charlotte
- '18 Golf R 6MT
I have 19x8.5 et 45. So I’ll have a few more mm
That's weird. Tire Rack only lists 2 offsets. 19x8 ET45 and 19x8.5 ET47
Someone tell me if the braking performance upgrade is worth it, over PP brakes?? The specs look good on paper...
I looked for wheels at Tirerack that fit an Audi TTS. I figured they would have a good chance of clearing the Macan calipers.Be sure to send me your final wheel and spacer fitments once you're sure so I can update the wheel fitment list.
Has anyone using the 340mm disc put some miles on their brakes yet?
I just checked my pads and it has a lip up top now.
Template for testing fitment with Macan calipers.
http://bd8ba3c866c8cbc330ab-7b...cdn.com/Q5_B8_BBK_Template.pdf
VCDS/OBDeleven optimizations
Here are some of the changes, but hydraulic brake assist is the only one your notice in everyday driving.
03 braking module security code 25757 worked for straight ahead brake stabilization. Turned it off and it'll allow trail braking into a corner without the abs fighting you.
03 braking module security code11966 worked for hydraulic brake assist. Removes the computer controlled brake boost that smooths out your braking and boosts braking pressure in panic stops. Gives you 100% control of brake pressure. Pedal felt amazing after turning off.
03 abs module Brake booster security code 25001. Factory setting 4, most use 2, I like 3.
First, I printed the template and even after verifying the 2 inch box, it does not fit the center bore of the gti. If I correct for the 57.1mm bore, even the overall length does not fit inside an 18 inch wheel.
What gives?
Secondly, If I don't do the OBD11 changes would this still be a worthwhile upgrade for autocross?
