Finally got to go for a spin after bleeding the system three times. Unfortunately there seems to be a dead zone at the top of the pedal. I have the standard Golf/GSW master cylinder currently, but I don't believe this is the issue. It's likely caused by the "low drag" design of the Macan calipers. Maybe some ABS stops and a rebleed will help, but it seems unlikely.
I did not experience the dead zone with any of the following setups using the same master cylinder:
288 OEM / 272 OEM
312 OEM / 272 OEM
312 ProdigyWerks CR4 / 272 OEM
312 ProdigyWerks CR4 / 310 OEM
340 Neuspeed / 272 OEM
340 Neuspeed / 310 OEM
Everything else seems great! They look freakin' awesome; I love the color! A note for RSe05 fitment. 1/4oz wheel weights do not clear on the spoke side of the barrel. 1/8 might clear, but if the weights are mounted beyond the step in the barrel they will clear without issue. I have this same clearance problem with my Neuspeed 6 Pistons.
