Just wanted to see if someone can confirm. I'm putting these on my R (looks only), and I recently put on new pads/rotors. I can just keep my 340mm rotors and buy the calipers, lines and z26 pads? I don't care for the wear sensor, it's bypassed.
YesJust wanted to see if someone can confirm. I'm putting these on my R (looks only), and I recently put on new pads/rotors. I can just keep my 340mm rotors and buy the calipers, lines and z26 pads? I don't care for the wear sensor, it's bypassed.
It means you have the wrong code for your car.I’m having trouble coding the hydraulic brake assist off and changing the brake booster value. I have OBDELEVEN, when I’m in the adaptions for module 3 ‘brakes’ I set to not active enter a valid security code. It’s gives me a successful tick but the asks me for a new code, over and over again. Without making the change. Anyone else experienced this?
mice tried updates, reboots, bonnet up, everything
Help please
But the codes are still getting a tick not a crossIt means you have the wrong code for your car.
I’ve made a video showing the odd thing that’s happening to me on my OBDELEVEN. Can someone please watch this and tell me if I’m getting something wrong? The cars ignition is on and the hood is open. There are also no current fault codes
Saw this in a Facebook ad and it seems that cayenne 6 pistons also work and they are also 340mm?
interesting....those brotiforms look to have like a stepped "interior lip", it may very well touch.Is it likely that an 18inch wheel barrel would not clear the top of the caliper?
Got a set of 18x8.5 et 45 Rotiform las-r wheels, printed out the template in the first post.
I was concerned about the caliper hitting the front of the wheel but was not expecting clearing the barrel to be an issue.
Am I doing something wrong? I made sure to center it when doing actual measurements to the hub (its off a bit in the p
Is the caliper rebuild kit only for those that are powdercoating the calipers? I just realized that is the one part I didn't order yet.
How did you know my real name?I power coated and reused all the factory parts/ seals. I did not need a rebuild kit. Just be careful.
If your name is Edward Scissor Hands Arcadia, you might need the rebuild kit.
