Raguvian
- Bay Area, CA
- 2019 GSW 4MO 6MT
Best way if you haven't installed them yet is to pop out the pistons with an air compressor and lather the grease on the sides.
Is it feasible with replace the dust seals without removing the caliper? My thought is remove pads, remove caliper from knuckle, then gently use pry tool/pliers to remove dust seals and insert new ones. Doable? Worries about getting the new dust seals in the correct position (so that it seals properly)
So I don't drive my car hard. I don't track it
I don't do autocross. Hell, aside from on ramps with no traffic around, I hardly ever even hit peak boost. Because of that, I don't slam my brakes or press the brake pedal as hard as possible.
Well, today I did, and could feel my pedal very slowly sinking. Which isn't good.
Get home, and can see it immediately. Brake fluid all around my wheel and wheel well. Which means a piston is leaking.
Yup.
Take it apart, which I'm getting very good at by this point, and sure enough the inner seal is knicked. Luckily, still have plenty of extras. Put it all back together, bleed them, and they feel good so far. But it was raining, and really didn't have a chance to press them too hard.
You have terrible luck with seals.
What brake fluid are you using? Didn’t someone running Castrol SRF have an issue with fluid seeping?
What rotors are those? They look great.
I have the same, and in hindsight I should have just sprung for 2-piece guys to save weight too. They do look great though!Stoptech Drilled & Slotted 127.33112. Them looking great is the only reason I spent $320 on rotors lol.
I'm in it for aesthetics only, went with R1 concepts Geomet rotors, Mk6 R... they were $190 for the pair. Regular price $270 but R1 has somewhat regular 30% off sales.
