Acadia18
2019 Golf R
Why do yours look so much bigger than mine and mine are behind 17" wheels.
It's all in the angle of how you photograph it 😉
GTIfan99
Come photograph mine please, because they look small.
Will_
SF Bay Area
2017 GTI S DSG
?Confirming Macan brake line part number: 95B-611-776-A ??
Chris at Techna-fit says they will not be able to provide a SS line for 45-60 days. So I'm ordering the standard Macan flexible brake hose from Porsche and want to confirm its part number. Can anyone confirm the above number is the correct part number?
Thanks,
Bern
That shows up for me as the brake line for the cars with CCBs. I think you want this guy: https://www.sunsetporscheparts.com/oem-parts/porsche-brake-hose-95b611701e?c=Zz1icmFrZXMmcz1mcm9udC1icmFrZXMmbD0zMSZuPUFzc2VtYmxpZXMgUGFnZSZhPXBvcnNjaGUmbz1tYWNhbiZ5PTIwMTgmdD1iYXNlJmU9Mi0wbC1sNC1nYXM=
95B-611-701-E
Bernb6
Palo Alto, CA
2017 GTI Autobahn
Will, thanks, I was just ordering them this morning,
Bern
tigeo
DELETED
GTIfan99
I rebleed the brakes pre track day coming up this weekend. They feel really good. RRG, some ABS stops and a good 30 psi bleed LF, RF, LR, RR is all it really takes.
nono0044
Toronto
I'm sure you covered this somewhere, but you post so frequently I couldn't find it via your profile:
How do you apply the RRG with the pistons still in the calipers? I might try to grab some and apply the next time I bleed mine
Acadia18
2019 Golf R
He's mentioned just lifting the dust boots, and cramming some under there.
GTIfan99
Not the best method, but, I removed pads, removed caliper from knuckle, removed dust seals,, hung with a caliper hanger on control arm, put 1 pad in the caliper, gently pressed brake pedal, greased pistons (outsides seemed to always extend, so used a wood working clamp to hold the pad against them, so I could get the inside to extend out too), greased, put it all back together.
Not ideal, but it made a difference for me.
GTIfan99
It was a little better than that. I went back and pushed the pistons out and THEN crammed some under there.
I'm not a savage.
