patrick_b
Newburyport, MA
2017 GTI SE 6MT
How do you like them? My OEM PP brakes are at 60K and I just ordered the FCP cross drilled/red stuff pad kit. I didn't buy fluid yet. I know my mechanic will use OEM. I have a track day scheduled for Oct but I will probably do 1-2 per year.
For reference:
https://www.fcpeuro.com/products/audi-vw-brake-kit-zimmerman-sport-kit-528841kt18
Will_
SF Bay Area
2017 GTI S DSG
vwlotech
Lexington, KY
For reference:
So far so good! they've only been on for a couple days, but no complaints as of yet.
VL3X
Delaware
2017 GTI SE
Don’t do a track day with stock fluid, it will boil quickly and you’ll lose brakes. Change that first.
Depends on many factors.. but I have done a few tracks days on the stock setup without issues... UNTIL my last 20 min session of the day and experienced some brake fade and went off the track a bit. One of my Neuspeed RSE10s left with a bit of a bend and had to be replaced. That being said... upgraded brake fluid would have been cheaper.
Will_
SF Bay Area
2017 GTI S DSG
From Konig - 18x8.5 ET 43 Ampliforms won’t fit - although not sure if they scaled template correctly?
Sspcivic31
Texas
So I have an interesting problem that I didn't see listed anywhere in this thread.. fluid escaping from the threads of the bleeder screws?
Hi, I have a mk6 gti that i fitted the 986 boxster calipers to, and had a similar fluid weep issue. only thing that fixed it was to remove the rubber bleeder covers completely, torque the bleeders then reinstall the rubber covers. weeping stopped after that. best i could tell the lower loop on the rubber was thick enough to keep the bleeder from seating properly.
nono0044
Toronto
Hmm interesting, going to give that a try as well since one of the loops looks to be pinched
rotaryguy
Getting closer to getting this done, high temp boots and seals are in, only piece left is a set of wheels,... that should ship today... hopefully...
Powder coat shop did a great job flowing them, I see really no orange peel like others have. What color is that called?
bentin
Austin, TX
23 Golf R - 3 Pedals
Yeah, prep work is so vital to powdercoat. The shop I used had a vat of something capable of straightening your DNA coils, but it sure made for a clean surface. Also comes down to using the right temp and providing a suitable cool down cycle.
vwlotech
Lexington, KY
exactly, the shop I use, blasts everything down the bare metal.
