I drove it on the street, so zero.How many high speed stops did you do?
The Macan brakes are fine for the most part on the street. It's when you go to press the pedal at 85+ is where the trouble starts...I drove it on the street, so zero.
I'm not having an issue with that with mine.The Macan brakes are fine for the most part on the street. It's when you go to press the pedal at 85+ is where the trouble starts...
i've tried multiple pads and same dead spot issue, especially when coming from from 130+ which leads to inconsistent braking markers and less confidence....and that oh $hit moment which the car turns into locked brakes....I have to say I haven’t had any braking issues at high speeds, the only thing I’ve gotten is a little shimmy from the rear braking from 110-40 downhill into T2 at Laguna. Otherwise they’ve been fine.
I now can't find either of my new master cylinders, haha. I will find them eventually. Way back when I was going to 6 pot brakes on my Golf my research told me that my car had a smaller MC (didn't know the size) but that GTI/R/S3/TTRS/etc. all used the same MC which I assumed would be bigger, which is why I ordered it.
What's annoying with car compatibility lists is that even parts.vw.com doesn't always differentiate. For instance, they might show the larger MC as fitting everything from the 1.4L Golf through the Golf R. And in fact it does fit, but it's not what came on the 1.4L. But that could lead you to believe they have the same MC when they actually do not.
I drive a Golf TDI and I drive it slowly, so no benefit to any larger brakes for me. I'm actually switching out my 6 piston 17Z's for the smaller 4 pot Macan calipers, haha.If I didn't have PP brakes to begin with, I would have stayed with none PP rears. No benefit to the PP rears.
Wouldn't help with Brake bias?If I didn't have PP brakes to begin with, I would have stayed with none PP rears. No benefit to the PP rears.
Seeing as sequential TCR race cars used non-PP rears, I'd guess not.Wouldn't help with Brake bias?
You're the last hope lol, the only surefire way of telling. Only then can we put this to rest. Anything else is still guessing.
Irrelevant, but I have no clue why I'm even doing this lol, I don't have Macan brakes, nor do I have an issue with my stock brakes and I go very hard on brakes at the track.
Anyways, find them haha.
I think it is a lot more than a guess. Not only is VW telling us (with the fitment guide) that they are the same, we also have all this photographic evidence of actual MC's pulled from cars made in 2015-2019. Unless you think that is all somehow fake?
I do agree it is a bit confusing with all the different models and part numbers, as to which ones have the 23.8 mm piston like the one you bought. You never answered, do you no for sure what car that came out of? Oh unless, is that outer lip I was referencing on yours something other than 46 mm? Seems highly unlikely, but that would certainly throw off the photo measurements if that was the case.
More confirmation never hurts, but I think at this point we have more than enough information to say with a high degree of confidence that all the MK7 GTI's and Golf R's already have a 25.4 mm MC piston, no?
Just saying we do have evidence, so it is far more than just a guess. Physical evidence is better of course, but the photos (especially from independent sources, and several different cars/vendors) is far from nothing. I found the measurements to be pretty conclusive, try it yourself if you don't believe me.Why is it so hard to believe someone wants to verify physically vs via photos? Just because not everyone is a pushover doesn't mean everyone should just settle for a shortcut, especially when we know someone here WITH BOTH MASTER CYLINDERS.
Patience is a virtue, what's the rush, not like anyone here is on a schedule....
