@GTIfan99
Here's a direct link for the brake lines if you're still around. Unfortunately, the price has gone up.
Thanks for putting this together.
https://www.fast-turbo.com/techna-f...k7-gti-with-brembo-macan-calipers-front-only/
Does anyone have any leads on the red grease? Is the stuff on Amazon the real thing?
I added the link to the initial post.
I'm trying to get mounting hardware made that will allow Chevy/ Cadillac 6 pots to be used with the new mk8 R rotors. If I can make that happen, I'll post the details in here and I'll start a new thread.
I saw it on some id4 facebook group. The poster didn't really give out any details.
Those looked like Macan calipers, but I thought the ID.4 has same size rotors as the R.
dcgtimk7
DC
They are macan calipers. Yeah the id4 has 358mm x 30mm. Some of the id4/q4s with the vin wvg have 330mm x 23mm rotors. I think the id4 in the photo has 358mm rotors.
My mind can't process how Macan calipers would fit with 358mm rotors. Are ID.4 MQB based? I'd guess they just use a different caliper carrier for the stock sliding calipers to go from 330 to 258, but with how the Macan calipers mount, I can't see an adapter working.
That picture breaks my brain.
dcgtimk7
DC
Knuckles are probably different.
aus
California
MK7 GLI
Can anyone confirm if 034 or any other brand ball joints fit ok for more negative camber? Or should we use camber plates or EuroSport Street camber inserts?
scrllock
MI
This upgrade uses stock rotors, so there's no reason you can't use any balljoint you want.
  • Like
Reactions: aus
