Im using the Porsche pins, definitely the right size.Which pins are you using?
The Porsche pins seem to be the correct length. Those that came with my power stop pads are too short.
Sounds like a violin, If I press the paddle just right at under 5mph, It can be very loud almost like train. But during normal driving it comes and goes, mostly when turning from stop or creeping in traffic. Once I let go of the paddle, it will persist up to 5 - 10mph but incrementally, almost like a bad bearing.I'd really recommend crc silaramic, especially where the pins might rub on the pads. What noise are you having? Are you using a good street pad, or trying something a bit more performance -oriented?
Looks good. See if they sell the pads for 2003 - 2016 Subaru STI or Mitsu EVO.will the ferodo 3.12 fit? anyone have the p/n? i checked their site and they say only the ds2500 are compatible which i dont want. do i just order 3.12's and say the 1001 version??
btw the soft pedal isnt a bleed issue its a small pump problem. can be fixed with gold version wilwood inline in wheel well.
i've had these brakes 2 years now so far so good looking for more aggressive pads, i got them with stock porsche pads. i am using the 2pc DBA 345mm rotors.
passat bitdi > r8 wheels (no spacers required) cup2 tires, 310hp/480ftlbs 2.0 tdi haha
Looks like a squeal tab, so when the pad material wears down it’ll start making noise, your indicator to change them. Some have them, some don’t.Stupid question time, what is this little clip on the pads. Did I put these pads in wrong?
As someone said, it's for wear. It makes noise when pads are worn.Stupid question time, what is this little clip on the pads. Did I put these pads in wrong?
