DSC808
HI State
2016 GTI SE MT
Does any of the caliper mounting hardware need to be replaced? I thought I remember only the rear carrier bolts were one time use but I could be wrong.
Should be replaced. FCP Euro x 4
N91084901
  • Like
Reactions: krs
VW says every bolt should be replaced. Of all the bolts on the car I wouldn't replace, I wouldn't replace these.
But I swapped out my suspension using a 2 x 4, so take as you will.
scrllock
MI
On the front you normally just replace the caliper to carrier bolts. The macan caliper bolts to the knuckle directly, and the manual says those bolts can be re-used, just "cleaned if reused."
mk6'12gti
Cleveland
2018 Mk7.5 Gti
I just installed the macan calipers and did some of the vagcom coding but I couldn't do the last part of it.
"03 abs module Brake booster security code 25001. Factory setting 4, most use 2, I like 3."
What is the security code for this because 25001 is not a valid security code for the abs module
DSC808
HI State
2016 GTI SE MT
Trying to get the crossover tubes back in and I can't get it to sit flush. Should there be some threads showing?
Leave it alone. I went back to 4. It was causing fronts to overheat on track and properly greasing the seals and proper bleeding makes all the difference.
TheBlondeFella
UK
MK7 Golf R
Is the Castrol RRG the only RRG recommended? Are there any other reputable makes worth considering eg Granville or Silverhook etc.?
@jay745 has recommended something that's less goopy than RRG, but no one has tested if it's reduced the piston refraction.
jay745
What Would Glenn Danzig Do
Slightly Outside Chicago
Mk6 racecar, Tacoma
RRG isn't for brake pistons, it's for rubber. It dries out and will seize your calipers. Use brake assembly fluid and get a master cylinder that can keep up with the brakes if going bigger.
/Thread
/Thread
It's 100% formulated for natural and synthetic rubber seals and boots. It's specifically stated by Castrol that it can be used for assembly of brake calipers.
And can you point me to a better master cylinder?
jay745
Mk6 racecar, Tacoma
And can you point me to a better master cylinder?View attachment 275033
Sounds like Castrol formulated something different than the normal RRG. Didnt know, your car - use that then 🤷
And no, pairing the right master is a huge guessing game. Most find it easier to go with a stoptech or wilwood kit that is proven to work great with the master and rear bias for vws
I'm pretty sure we have the biggest MC stock that you can get for this platform, unless the mk8 got a bigger one, which I don't think it did. They did change the ABS module to feel firmer, right up until the fluid boils and you drive off a cliff.
