Do you guys have the RPV's or are you having the issue without them?
If it's without, it sounds like you aren't getting enough pad retraction. Maybe try the factory grease if cleaning doesn't help. Just a thought.
flipflp
Los Angeles, CA
'16 Golf R DSG
No valves. I've got a few track days, pad swaps and many street miles on the calipers and this squeak started about a month ago.
I'm not going to do this scientifically to see what fixes it, but I am going to:
Pack in RRG
Swap back to the original dust seals (I have the RB ones now and they never fit great TBH)
Install new Posi-Quiet pads (105.16630) meant for the Macan
Lube pins/pads with Permatex Silicone lube (24129)
Will report back!
Raguvian
Bay Area, CA
2019 GSW 4MO 6MT
If the dust seals didn't fit great I can see those not allowing the pistons to retract properly. The Macan calipers are low drag (hence why the pedal can feel squishy) so I'm surprised you're getting drag in the first place.
I drove my brother's R with the stock 340mm single piston calipers and his pedal feels way stiffer than mine but the brakes don't bite as well at all. I vastly prefer my softer pedal feel now (at least on the street) now that I'm used to it.
flipflp
Los Angeles, CA
'16 Golf R DSG
They fit the piston great, but didn't fit as snug in the caliper as the factory parts so that could be contributing to them not retracting. The seal isn't tugging back on the piston at all if the seal is just floating.
Raguvian
Bay Area, CA
2019 GSW 4MO 6MT
The dust seal shouldn't be pulling back on the piston; that should be done by the square seal inside the piston bore (unless I'm misunderstanding what you're saying).
I drove an R and my GTI back to back at an autocross this last weekend. Pedal felt identical to me.
I really liked the R. Good thing I didn't drive one before buying the GTI. Lol.
flipflp
Los Angeles, CA
'16 Golf R DSG
No you're good, I'm probably giving the dust seal more credit for piston retraction than it deserves. You had said if it didn't fit well it could be hanging, but the seal is loose in the housing so if anything it's just not doing it's job sealing.
Raguvian
Bay Area, CA
2019 GSW 4MO 6MT
I was just thinking if it was hanging it could be getting in the way of the piston retracting properly, but it's just a guess.
I always forget what the consensus was, but I think I have the even smaller M/C since I have a 1.8? Either way the brakes work the way I want them so I'm happy.
Benjimk7
McKinney, TX
2017 GTI Non-PP
So question. I have gone thru like 25+ pages on this thread. I am considering doing this upgrade to my fronts. I have a non PP Gti, so little brakes. However, with upgrading the front, do I need to upgrade the rears to the macan rears? If so… are there listed part#s?
also really stupid question… because im just curious. Could you use front brakes as rears? Idk im just wondering.
Will_
SF Bay Area
2017 GTI S DSG
No and …I don’t know if anyone’s tried that, but likely no.
No, no, and not needed. The non-pp rears aren't an issue at all.
Raguvian
Bay Area, CA
2019 GSW 4MO 6MT
Rear brakes have the parking brake integrated, so no you can't put front calipers on the rear.
Aluizio
Brazil
After a long time, I had a opportunity to test the Macan Brakes on track. Unfortunatelly the car had DSG problems and just did some laps.
I'm happy with the result so far, but need to test more after solve the DSG issue.
