Raguvian
- Bay Area, CA
- 2019 GSW 4MO 6MT
15psi isn't even 1bar of pressure.
Same. I bled mine at around 25psi.
So? It's still enough to push fluid through. On other cars I've had no issue pushing fluid through at 12-15 psi.
I honestly don't know, but 12 psi seems low. I bleed at much higher pressure. IIRC, VW recommended 29 psi.
Huh, I guess you are right.
I'm assuming the clutch can be bled at this pressure too? I guess the system sees much higher pressure when you're actually on the brakes or clutch?
