Hey guys, wondering if someone has any advice for me.
Yesterday and today my car has been acting strange. It's a golf 7.5 GTI with DSG 6 speed and for some reason the gear changes have been acting different. They have suddenly started changing up later at higher rpm and seems to not want to go into 6th gear. It's particularly noticeable in Eco mode. I can change up manually to 6th with the paddles but after a few seconds it jumps back to Eco 5. It appears as if it doesnt think I'm at the right speed for 6th gear or something (even at 60 on a flat road).
This isn't the only issue though, the temperature sensor for outside is now fixed on 49 degrees C, which is obviously nonsense for Scotland...!
The only other issue I have noticed is with the AC control. I can turn on/off, change fan level etc but it won't change the temperature. Last setting I had it on was lo or 16 but I can turn it up past 20 and it's still blowing out cold air.
Any suggestions would be appreciated. I don't have a fault code reader but half tempted to go get one to see if it shows up anything. Also was thinking to do a full reset by disconnecting the battery and letting it discharge but not sure if this will cause any problems with resetting? Will anything need reprogrammed etc after a reset that will require a dealer? Or is any kind of reset possible to do myself?
Thanks for your help
