Compressor turbine toast
Gvazquez
North Carolina
Was there no sign of an object in there when you took the inlet off? How's the turbine wheel looking?
Hollywood0220
NW
German/Japanese
Doesn’t appear to look out of the box New.
Are you running a “no filter” air box? It looks like fine granules blew through scuffing the blades....
n8s12981
California
No sign of any object when I pulled the inlet off, Just aluminum dust.No damage on the exhaust side. I'm running an apr intake. I cleaned the filter when I put it back together... No shaft play... Can I get a new compressor for these? Is that a thing??
ChrisMk77
Sweden
2018 GTI Performance
As Diggs said but I would also consider the compressor housing junk for a standard wheel, it looks slightly damaged and the tolerances are most likely out of spec.
Littco sells L380 supercores that runs on IS38 tunes but has stronger bearings and improved compressor wheel.
https://www.littco.co.uk/l380-turbo-74-p.asp
