While the Fender System is fairly good for an OEM system, it is still somewhat lacking compared to other systems I have built. I therefore started to look at what could be done to make it better. My goal was to spend as little time and money as possible, and not upgrade the Head Unit or Amp. I was not able to find much complete info on anyone doing this upgrade (of all the speakers), so will try to provide this here. While this is not a how-to post, what will be covered are some of the issues/challenges (pics provided) that I found throughout the install.
Stage 1 - Subwoofer
A quick search on this forum and others indicated to me that the OEM Sub is the weakest link in the Fender system. This is where I started, replacing the OEM box with a 10” Fosgate R2 (low profile) Dual Voice Coil Sub in a custom enclosure. This is pretty straight forward and the parts required are readily available online (including the required part numbers).
My goal was to use the smallest box possible to maximize the available space under the trunk deck for emergency equipment and gear that I normally store. I wanted to keep the jack in stock location and keep the spare. I could have used the 12” version, but this increased the box size and I was not looking for any major bass upgrade, just the minimum improvement upon the 6” version. There is also a 10” P3S version, which can handle more power (and costs more), but I was not planning on adding an amp. As well, one could use the 8” version, but the space/cost savings would not have been that significant. The 10” R|2 seemed just right for me.
I used ½” Birch Ply to minimize the overall depth but had to add additional supports inside the rim to increase the box’s rigidity.
This worked out well and I used poly fill inside the enclosure (about 8 oz). I did not add terminal connectors on the outside, and instead just passed the wires through the box. Seemed redundant to have a quick disconnect, when I was going to use the stock OEM connector. I was not planning to take this in and out a lot.
Because I reduced the size of the box, it would sit squarely on the spare tire. I was concerned having a box with a down firing Sub, sealing around the spare tire and not allowing enough air to flow. So, I added stand off’s to keep the box off the tire. To keep the box from shifting, I added posts that would grab the sides of the tire.
I was also concerned the plastic spare wheel lock down nut sat too high in the wheelwell and might interfere with the throw of the speaker. Therefore, I reduced it’s overall height by a couple inches.
While I likely over engineered the box, it ended up very ridged and I had the tools to be able to do the work. I also just used a rattle can to paint rather than fabric wrap the box. This reduced the overall size slightly and cost of labour for me. Here is the final position in the trunk.
The final outside dimensions were 23 3/8" W x 21” H x 4” D, unfortunately this did not work out from one 2' x 4' sheet of ply but I had some extra material left over from another project. Though I did not weigh it, I estimate it is 22 to 25 Lbs. After this upgrade, I dropped the Sub setting on the head unit from +2 to -1, as there was significantly more bass.
VERDICT: Recommend this upgrade 110%. At around $200 CND cost, this made a noticeable difference in the system sound. I can feel the Sub through the seat now and the bass is sufficient for my needs. If you want to just do the minimum work to get the best sound out of the OEM Fender System, this is all you will really need IMO.
UP NEXT: Stage 2 - Door/Pillar speakers
Stage 1 - Subwoofer
