xXDavidCXx
- AZ
- 2017 GTI SE DSG
Unfortunately, generic shocks bodies with application specific hardware are not designed enough for a particular application to be worthy of being referred to as designed for a particular car.1. I bought a kit "designed" for my car. I expected it to work in the configuration in which it was sent to me- it never has.
Custom shocks with the body cut down or built up for the specific car’s needs for bump and rebound travel and valving are “designed” for a particular car.
Anything short of that above is just a compromise in ride height, travel, or both.
You would likely be fine with the stiffer springs since the shock is adjustable with a range of forces.5. It would appear the only solution - as David said - is stiffer springs, or somehow more pre-load, but even as shown below, the ring is damn near impossible to turn. I believe this to be the only solution at this point. I could swap on the 8k springs I still have... but will the street vs comp valving had made a difference? Plus I think I'll be over sprung for my current valving. So at what spring weight will it stop?
I believe there is one rebound force needed for a car, based on the car’s un-sprung weight, and this value rarely changes, expect with payload and fuel changes.
In racing applications you can closely control payload, so the desire rebound curve is very narrow and bump/compression forces required are grip based (tires/temps/surface grip).
Having an adjustable shock allows a wide range of desired rebound curves based on the possibility of a wide variation in un-spring weight.
What race specific valving usually does is adds low speed bump and rebound, which street shocks do not have, for comfort reasons.
For example, here is a front shock dyno from my Ohlins.
Even these shocks are a compromise because bump and rebound are adjusted at the same time.
If you are reading a shock’s design features and it mentions that adjusting both at the same time is a good thing, walk away.
The best setups have separate controls for bump vs rebound.
That being said, for the $$$ the Ohlins R&T setup is really good.
Look at the forces below 3 inches per second as the adjuster is turned. Lots of rebound (bottom) and a moderate amount of bump (top) is added.
I can’t control the forces separately so if I set the forces to give the correct rebound for the spring rate and un-spring weight, I probably don’t have the correct bump setting for the conditions of the day, which then may drive me to soften rebound to get less bump, causing the vehicle weight to be under dampened.
Anyway, shock rant over.
No one but Red shift can answer this question.8. I'm just gonna ask this again. How or why is this like this. Shouldn't this have come to me working? I shouldn't have to "fix" this shit. It's not like I cobbled together part from ebay.
