MrConflicted
- Salt Lake City, UT
Hey Everyone! I've been collecting information on some coilover kits for our cars so I thought I would share the findings. I'm going to keep updating it as a find more. Right now the list focuses on mid-high end kits, but if people are interested in lower end stuff let me know and I'll add that as well Also if you guys are interested in drop rate ranges, let me know and I can add that as well.
IF YOU HAVE ANY FEEDBACK ON HOW TO MAKE THIS BETTER, PLEASE COMMENT
Some info is harder to find than others, but I want to make this as comprehensive as possible.
General Notes:
The kits stated are for the GTI. They might work for Golf/R/A3/S3, but you'd have to look in more detail.
All coilover kits with camber adjustment offer about -1.5/+1.5* of camber adjustment at STOCK height. A rough (and I emphasize rough) estimate of camber increase will be about an additional -0.5* of camber for every inch lower than stock. (Gathered from my alignment with lowering springs, and some discussion with various vendors).
STOCK SPRING RATES: (from Neuspeed website)
A3 Spring Rate: Front - 130 lbs/in, Rear - 165 lbs/in
GTI Spring Rate: Front - 175 lbs/in, Rear - 230 lbs/in
---- FORMAT ----
Coilover: $PRICE
Front Spring Rate:
Rear Spring Rate
Front Lowering:
Rear Lowering:
Camber Plates? -
Adjustability
Prices are more or less from ECS Tuning, however, you can often find them cheaper. Only use the stated figures as a ball park. For the spring rates, I called manufactures if the items weren't listed.
I've tried to list these from Street Oriented to Track Oriented.
========== BUDGET COILOVERS ==========
For those that just want low.
ECS Tuning Economy Line: $499
Front Spring Rate: TBD
Rear Spring Rate: TBD
Front Lowering: 1.2-2.3"
Rear Lowering: 1.2-2.3"
Camber Plates? - No
Adjustability: None
Solo-Werks S1: $499
Front Lowering: 1.4-2.5"
Rear Lowering: 1.4-2.75"
Camber Plates? - No
Adjustability: None
========== STREET/TRACK ORIENTED COILOVERS ==========
Coilovers comfortable for the street, but that can handle a weekend at the track
everyone once in a while!
ST X: $807
Front Spring Rate: 15-20% over stock, progressive (~175lbs/in)
Rear Spring Rate: 15-20% over stock, progressive (~150 lbs/in)
Front Lowering: 0.6-1.8"
Rear Lowering: 0.8-2.0"
Camber Plates? - No
Adjustability: None
Vogtland: $999
Front Lowering: 1 - 2.2"
Rear Lowering: 1-2.2"
Camber Plates? - No
Adjustability: None
AST 2000: 660 Euro
Front Lowering: 30-60mm
Rear Lowering: 30-60mm
Camber Plates? - No
Adjustability: None
STX - Adjustable: $1427
Front Spring Rate: 15-20% over stock, progressive (should be in the 175lb/in range)
Rear Spring Rate: 15-20% over stock, progressive (should be in the 150lb/in range)
Front Lowering: 0.6" to 1.8"
Rear Lowering: 0.8" to 2.0"
Camber Plates? - Yes
Adjustability: 1 way adjustable, rebound dampening
Notes: Not recommended for more than occasional track use.
KW Variant V1: $1519
Camber Plates? - No
Adjustability: None
KW Variant V2: $1939
Quote from actual ST/KW Rep: "STX and V2 use the same shock and spring. The difference is in the housing, camber plate and warranty." Rep could not quote exact spring rate. Still a "street-focused" kit.
H&R Street Performance Coilover: $1428
Front Lowering: 1.1-2.3"
Rear Lowering: 1.0-2.0"
Camber Adjustment? - No
Adjustability: None
Forge Motorsport Coilover: $1200
Front Lowering: TBD (Fully threaded body)
Rear Lowering:TBD (Fully Threaded Body)
Camber Adjustment? - Yes
Adjustability: 1 way adjustable dampening.
KSport Kontrol Pro: $900
Front Spring Rate: 504 lbs/in (9K)
Rear Spring Rate: 252 lbs/in (4.5K)
Front Lowering: TBD
Rear Lowering: TBD
Adjustability: 1 way - dampening adjustment (36 levels)
BC Racing BR: $995
Front Spring Rate: 448 lbs/in
Rear Spring Rate: 336 lbs/in
Front Lowering:
Rear Lowering:
Adjustability: 1 way adjustable, rebound dampening (30 clicks)
Swift Springs available for ~$320 extra (custom rates)
--> My personal review available here: http://www.golfmk7.com/forums/showthread.php?t=30523&highlight=Coilover+review
Bilstein PSS (B14): $995
Front Spring Rate: progressive, TBD
Rear Spring Rate: progressive, TBD
Front Lowering: 30-50mm
Rear Lowering: 30-50mm
Camber Plates? - No
Adjustability: None.
Bilstein PSS10 (B16): $1923
Front Spring Rate: 399 lbs/in, progressive
Rear Spring Rate: 423 lbs/in, progressive
Camber Plates? - No
Adjustability: 1 way adjustable, rebound and compression (10 clicks)
Bilstein B16 Damptronic
Front spring 65N/mm 371lb
Rear spring 55N/mm 314lb
Front Lowering: ?
Rear Lowering: ?
Adjustability: ?
AST 1-way 5100: $1625 Euro
Front Spring Rate: Custom Available
Rear Spring Rate: Custom Available
Front Lowering: - fixed, or coilover option
Rear Lowering: - fixed or coilover option
Camber Plates? - Available for $395 Euro
Adjustability: 1 way adjustable rebound
VWR StreetSport: $1299
Front Spring Rate:
Rear Spring Rate
Front Lowering:
Rear Lowering:
Adjustability: None
VWR StreetSport Plus
Front Spring Rate: Progressive*, TBD
Rear Spring Rate: Progressive*, TBD
Front Lowering:
Rear Lowering:
Adjustability? 1 way, dampening (12 position).
* = Linear Race Springs Available.
Ohlin's Road & Track: 2425 Euro
Front Spring Rate: 400 lbs/in (70N/mm )
Rear Spring Rate: 285 lbs/in (50N/mm)
Front Lowering: 15mm
Rear Lowering: 20mm
Adjustability? Rebound and Compression (not specified if on separate toggles)
========== TRACK ORIENTED COILOVERS ==========
Coilovers oriented for the track. Usually have very high spring rates and stiff dampening.
KSport Kontrol Plus: $1755
Front Spring Rate: 806 lbs/in (16k)
Rear SPring Rate: 784 lbs/in (14k)
Front Lowering: TBD
Rear Lowering: TBD
Adjustability: 2 way, rebound and compression
AST 5200 - 2way : 3200 Euro
Front Lowering: TBD
Rear Lowering: TBD
Adjustability: 2 way, rebound and compression w/ separate reservoir
AST 5300 - 3 way: 3500 Euro
Front Lowering: TBD
Rear Lowering: TBD
Adjustability: 3 way, rebound, hi and low-speed compression w/ separate reservoir
VWR TrackSport: $3299
Front Spring Rate: Linear, TBD*
Rear Spring Rate: Linear, TBD*
Front Lowering: TBD
Rear Lowering: TBD
Adjustability: 2 way, rebound and bump
Notes: Rear combines shock and spring (changes stock spring location). NASA TT-racers, this will cost you points! Front struts are inverted monotube.
* = Linear Race Springs suggest custom rates available.
KSport Circuit Pro: $2475
Front Spring Rate: 896 lb/in (16K)
Rear SPring Rate: 1008 lbs/in (18K)
Front Lowering: TBD
Rear Lowering: TBD
Camber Plates? - Yes (with caster adjustment too)
KW Clubsport (2-way): $3480
Front Spring Rate: 570 lbs/in
Rear Spring Rate: 460 lbs/in
Adjustability: 2 way adjustable, rebound and compression independently.
Bilstein Clubsport: $4146
Front Spring Rate: 571 lbs/in + 57lb helper spring.
Rear Spring Rate: 417 lbs/in
Camber Plates? Yes
Adjustability: 2 way adjustable, rebound and compression (10 clicks ea, 100 total combos)
H&R RSS+ Clubsport: $2519
Front Spring Rate: 628 lbs/in
Rear Spring Rate: 457 lbs/in
Camber Plates? Yes
Adjustability: 1 way adjustable, rebound and compression.
Notes: Also includes front swaybar links.
If you're still here - spring rates for our cars.
The GTI sits at about 61% F, 39% R weight distribution, which is close enough for our calculations. Your initial insight would suggest oh okay, so 61/39 ~ 1.5, so my front spring rate should be 1.5x stiffer than my rear. Incorrect! The front spring is a MacPhaeson Strut, meaning there is about 1:1 movement in the spring in wheel. However, the rear spring sits inboard. Because of this, we get about a 0.76:1 movement in the spring vs. wheel. To compensate for this difference, we need a stiffer rear spring. Specifically, about 1.31x stiffer (1/0.76). So for ideal weight distrubtion and equal suspension behavior front and rear, a good estimate is:
Where to get equal movement (X), we should set out spring rates (K) to approximately:
Front = 1.0 KX
Rear = 0.87 KX
Please note this is some very rough math, but should help you get an idea for why spring rates are set in a certain fashion! Also note, adjustments front and rear can help the car to behave to your liking, much like sway bars. Some like stiffer front, stiffer rear or anything in between.
General Notes:
---- FORMAT ----
Coilover: $PRICE
Front Spring Rate:
Rear Spring Rate
Front Lowering:
Rear Lowering:
Camber Plates? -
Adjustability
Camber Plates? - No
Adjustability: None
Solo-Werks S1: $499
Camber Plates? - No
Adjustability: None
ST X: $807
Camber Plates? - No
Adjustability: None
Vogtland: $999
Camber Plates? - No
Adjustability: None
AST 2000: 660 Euro
Camber Plates? - No
Adjustability: None
Camber Plates? - No
Adjustability: None
Adjustability: None
Front Lowering: TBD
Rear Lowering: TBD
BC Racing BR: $995
Front Lowering:
Rear Lowering:
Camber Plates? - No
Camber Plates? - No
Front Lowering: ?
Rear Lowering: ?
Adjustability: ?
Front Spring Rate:
Rear Spring Rate
Front Lowering:
Rear Lowering:
Adjustability: None
Front Lowering:
Rear Lowering:
Rear Lowering: 20mm
Front Lowering: TBD
Rear Lowering: TBD
Front Lowering: TBD
Rear Lowering: TBD
Front Lowering: TBD
Rear Lowering: TBD
Front Lowering: TBD
Rear Lowering: TBD
Front Lowering: TBD
Rear Lowering: TBD
Camber Plates? Yes
Camber Plates? Yes
Front = 1.0 KX
Rear = 0.87 KX
