Subliminal
- Vegas
- Slow FWD VW Hatch
I can't get to the 4th spark plug because when I try to remove the top nut holding everything down it spins but won't move its way up the bolt. I've tried wedging things under it and turning but still no luck. The bolt is NOT turning with the nut. I bought a dremel to cut off the top nut from a vertical angle but now I'm thinking it might be better to cut the actual bolt part below from a horizontal angle to avoid damaging the ground/metal-ring and replacing it with this bolt from ecs: https://www.ecstuning.com/b-genuine...hkXxAAsQoeqmpn7o46g24josssYDE0qhoCdI8QAvD_BwE
Anyone else have to do this before? Any tips/advice would be appreciated
