You can't compare what Jake is doing to these grounding kits, totally not the same. A grounding kit doesn't take long to develop while what Jake does to build a whole exhaust from the turbo back takes hours, if not a whole day.
I do what Jake does... so I know how long it takes to do. And for being a bespoke fabricator, his price is low... yet people complain about it.
What I mean is that while overkill, both Jake and EQT are using the best materials around, with specialized tools. Jake don't have to purge all the tubes he weld, going fast at a lower amperage will do the job, but penetration would not be the same and the weld joint can fail... as it happens in a lot of lower end exhausts.
EQT really don't have to use MIL PSEC wires and sleeves, but they do because they want to have the best item out. What would happen if one of those wires come lose, or the integrity of the splice joint fail? Detonation would be the least on my worries... stating that their grounding kit is way overpriced without taking into consideration overhead costs of a business, or the fall back if the kit fails and causes damage to a customer engine is not fair to them.
Yes, you can have the same quality in a DIY, ant it is going to be way lower than the asking price. That will be the case in EVERYTHING custom made/fabrication/etc... if you can do it, do it. If you can't, then ask someone to build it for you or pay the price.
OEM Spec TXL, GXL, SXL wire. Honestly probably do GXL for the terminal connections with a SXL main gauge branch. It'll last just as long as the rest of your wiring harness, solid stranded copper, cost maybe .25c a foot depending on your source.
I agree with you, I would go GXL, not for the terminals, but because it is used for high heat locations. But while Tefzel is more money, it's a better wire. The thinner multi-strand handles higher amperage. You can coil it tighter than DXL... if you can afford it, well worth the price.
Let's say I know of a place I use for all my electronic projects where I can get them for .30-.50 each, thin plated or silver. I used to buy the SMD for color changing the GTO's interior from them years ago.
This isn't a sealed boot to a sealed mil or other connector.
Their harness is sealed, that is the purpose of the Raychem SCL... it seals the joint were the splice is made from moisture, salt, etc. The Raychem DR-25 is the outer protective shielding.
This is why I say the harness is overkill, and worth the asking price.
This will work... everything cheap
GXL - heat shrink - connectors
EQT - MIL SPEC
Tefzel - crimp-on barrel butt connector - SCL - entirely covered in DR-25 - connectors.
