I usually do not see any codes, but today I saw some; P0139, P1114, P2181, and P3073
The cooling code, P2181, was near 700 miles ago with a frequency of 4. The fueling code, P3073, was near 650 miles ago with a frequency of 3. The two O2 codes were near 550 miles ago with a frequency of one and I am not too concerned with those two codes.
I will check the cooling system to determine which bit is causing that code. I believe it may turn out to be the thermostat. I have seen no fluctuations on the gauge, but I'll see later.
The fueling code makes me wonder, because I have the torqbyte PM3 but on the original oem LPFP. I am getting a new oem LPFP to upgrade to the DW65v or I will attempt putting my TTRS pump into the oem basket.
The P3073 and P2181 codes are a first for me and I have read quite a bit on them already.
Just thought I would post all of this and see what you all found to solve your issues with these two codes. Cheers.
