Aristocrat Autosport
GOLFMK7 Official Sponsor
- Buena Park, CA
The COBB turbo blanket insulates the turbine housing offering multiple benefits. It prevents the dissipation of useful exhaust energy improving turbo RPM acceleration. This leads to faster turbo spool and getting to peak torque more quickly. It also helps limit heat soak to neighboring parts of the turbocharger.
The COBB Turbo Blanket is designed to limit the amount of heat that is transferred from your turbocharger to your engine bay as well as keeping hotter exhaust gases that exit the system faster through decreased density. By limiting the amount of transferred heat, you extend the life of your under hood components, decrease intake temps, and improve the response from your car.
Constructed with a fragmentized fire retardant volcanic rock outer layer (Rated 1500°F Direct Heat / 1800°F Radiant Heat) and internally insulated with high temperature calcium magnesium silicate wool (Rated 1800°F Direct Heat / 2300°F Peak Heat).
PM IF YOU'RE INTERESTED
Facebook: Aristocrat Autosport
Instagram: Aristocrat Autosport (@aristocrat_autosport) • Instagram photos and videos
Website: www.AristocratAutosport.com
CALL OR TEXT: 818-660-6537
Email: Andrew@AristocratAutosport.com
- Direct fit for Mk7 Golf GTI/R
- Improves Turbo Acceleration
- Prevents Heat Soak of Components Near Turbocharger
