Unfortunately, even after switching back to the OTS Stage 3 map, I'm getting the error
On one of the MK7 facebook forums someone indicated you have to make sure you load one of the v110 maps. The v200 Cobb OTS maps are CCF ones that won't work. I also received the following from Cobb this morning...
"PJ Baltzor (COBB Support)
So I confirmed with our VW team and if you want to use the VCDS you would need to use a PRE ROMCON map on your MK7 Golf. I have mentioned this with them, along with your comments, and they will put it into the discussion as to future updates on this firmware."
