Clutchless ignition update: solved (maybe)
Ridebjj
lasVegas
Great work. The install does look like a real pain but kudos for figuring it out!
Well, like anything - it sucked ass the first time, especially with no guide / info to follow. If I had to do it again from scratch, it probably wouldn't be bad at all.
Ridebjj
lasVegas
Update: after nearly a month and 150+ starts, the only time it didn't work was after the cheap glue I used to hold the magnet on gave up the ghost and it fell off. Repaired with stronger bond.
Still no codes, faults, lights.
I'm calling this a success.
I'll try to make a more detailed diy in the coming days.
El_bigote_AJ
Las Vegas
2019 GTI bunny
haha, i was just gonna text you. what part of the VCDS/obd11 aspect helps?
Ridebjj
lasVegas
SELECT 03 Abs Brakes > adv measuring values > then type "clutch" into the search and select both the results. One monitors the slightly pressed position and the other monitors the full press. Both have to be triggered for no error starts and then both have to be deactivated after starting.
Push the clutch in and watch the screen and youll see which is which.
Ridebjj
lasVegas
is there any way that you can make the mount beefier? it might work in steel but since its only 2mm thick it wont hold up very well in plastic.
Theres a link to a copy of the 3d on tinkercad up above. Go nuts.
Ridebjj
lasVegas
Where did you end up running power from for the solenoid? I definitely want to take a crack at this.
From the fuse box behind the cubby.
bertj
Wirral (UK)
As I haven't driven a manual VW for many years I'm a bit confused about the safety aspect of this mod. Does the gearbox have to be in neutral and the parking brake or foot brake be on for this mod to work? If the car will start in gear there's a likelihood it could lurch forward (or backward) with unpleasant or dangerous consequences. There will always be someone out there who will cause such an accident. Imagine the litigation that VW would face if they had failed to install their cars with this safety feature.
Ridebjj
lasVegas
Car does not have to be in neutral nor foot on brake. Even if I knew how to make it that way I wouldn't have bothered, I always leave it in N with parking brake on anyway - unless I'm parked on a slope. It'd be on you to remember to put car in N first. Even so, if the parking brake is firmly engaged, there won't be any lurch. It'll just buck a bit and stall.
El_bigote_AJ
Las Vegas
2019 GTI bunny
What would doing a mod that’s bypasses the requirement of the clutch to be depressed to start the car have ANYTHING to do with a litigation with VW?
bertj
Wirral (UK)
If someone attempts to start the car when it's in gear without the parking or foot brake engaged the car may move when the engine fires. If a manufacturer hasn't taken this type of driver into account and an accident happens, then a stupid driver could attempt to blame the manufacturer for allowing the car to start in these circumstance. There are many incidences of drivers trying to blame a manufacturer for an accident. IMO having to depress the clutch before starting the engine is a sensible safety measure but keen/aware drivers such as on this forum would always check things before starting the car. Also would such a clutch modification cause warranty and/or insurance problems?
FlyingNugget
Toronto, Canada
Instead of putting the start requirement on the clutch pedal, they could have made the start requirement on having the car in neutral. Obviously, we can't DIY change the start requirement programming, but VW could have in the original design.
El_bigote_AJ
Las Vegas
2019 GTI bunny
maybe re-read the first post and what modification was performed, and then read my question again. How does bypassing the cars factory safety but VW at fault?
Ridebjj
lasVegas
Btw, at about 2 months now with this mod and except for the incident where the glue holding the magnet on failed, it's never not worked. I don't have to remind myself not to press the clutch anymore. I just give the stick a bop to confirm neutral and fire away.
Car is in pieces now, mid clutch install but when that's done, I'll possibly do the full diy on this. I got fuck all else to do outside the hours in my home office.
